Need help with crx to ek hatch swap
Old Dec 15, 2005 | 02:56 PM
BoostedEgHatchFl's Avatar
Default Need help with crx to ek hatch swap
I have a ek hatch thats already wired for obd1. I just got a crx with a b18a1 swap in it.I was wondering what all would I need to get to drop the ls into the ek.
I know I'll need:
obd1 dizzy
But would the mount in the crx work in the ek and what about the axles and shift linkage. I plan on going lsvtec turbo but theres just not alot of room in the crx
Old Dec 15, 2005 | 05:10 PM
Default Re: Need help with crx to ek hatch swap (BoostedEgHatchFl)
Bump someone help me out
Old Dec 15, 2005 | 08:18 PM
Slopoke's Avatar
You know, I could be wrong here, but I'm not sure if they make a hydro to cable tranny conversion for the ek.
Lets say they dont.
You'll need to get a hydraulic tranny(along with a hydraulic clutch disc), a rear tranny bracket for '99-'00 SI, the timing belt mount(the one bolted to the block) from a '94-up B series, a timing belt mounting bracket(bolts between the mount on the block and the stock fluid filled mount on the chassis) from a '99-'00 si.
In addition to the obd1 distributor, you'll need either obd1 injectors or wire in a resistor box for the obd0 injectors and obd0 injector clips. Also an obd1 ecu.
Lastly, the obd0 fan switch is located on the back of the block while the obd1 fan switch is located on the thermostat housing. So cut off the obd1 fan switch connector, extend the wires, then put the obd0 connectors on.
Thats all I can think of right now.
Old Dec 16, 2005 | 05:27 AM
Default Re: Need help with crx to ek hatch swap (Slopoke)
Thanks man
hondaOchibi7
38
Jan 21, 2011 01:55 PM
EFvtec Yo!
Nov 21, 2005 05:54 PM
PinchE NegRo
Nov 1, 2002 08:03 AM
