Later spool/Less Vaccum ???HELP
As the title states, I have just noticed this problem.... I have no clue what could be the cause or fix soo im relying on ur guys input
I used to be pulling about 20lbs of vaccum and about 22 when off gas during a coast...
But today i took the car out and it jsut sits around 18lbs @ Idle and 19/20 during coast
Also i noticed the turbo always spooled @ about 4k
Now it spooled very slowly nad wasnt fully spooled till about 4.5/5k
It also seemed to be a bit slower than usuall, untill about 5 grand it picked up
IDK but id really appreciate it if someone could give me some pointers!
Modified by R6E6I6D at 8:37 PM 12/15/2005
I have searched for a long *** time and all i have found which could pertain to the less vac, When the ecu senses a very RICH mixture it opens up the IACV to clean up emmisions and this could cause a controlled vac leak...
IDK, im still lost I am running sickly rich, but why didnt this happen before?
hey guys thanks for the replys but I have fine compression, and the idle is fine.... IAC counts seem to be a little higher than normal but nothing that would be to this extent.... I bought 2 1/8" compression fittings from ACE hardware, one of my buddys said it could just be a boost gauge leak which im gong to check... ill get back to you guys hopefully its not the rings
jdmgsrek9
Sep 20, 2013 08:20 PM
uszcrx
19
Jun 19, 2003 04:27 AM
