My 5th gen lude just die and won't start in the middle of the street..
Old Dec 15, 2005 | 01:16 AM
OxYi's Avatar
Default My 5th gen lude just die and won't start in the middle of the street..
I was just cruising on the street, and it was all green light during the night time, and I came to one stop, and all the sudden, the oil and the battery light came up, just like if you stalled the car. But as I try to crank up the car, nothing. The battery is good, the car just won’t start. No smoke coming from the engine, no pop sound that I am aware of..Not sure what is wrong..
Hopefully it is not my timing belt, currently at 66k. Or maybe was that I let me friend drove my car prior, and he was downshifting pretty hard, and when he stopped, I can see some smoke coming under my hood, but after that, I went on the freeway and everything was fine. After dinner, we went some other place and the car was fine as well, then as I was going home, it happened… freaking sucks…
anyone might be able to shine some light on the issue ?
Old Dec 15, 2005 | 03:32 AM
The Weather Man's Avatar
Check for fuel. Make sure you're pumping that fuel - check your fuel pump relay first.
Spark
Compression
Also check your starter.
Do a starter draw test...........steps
1: Pull the fuel pump relay
2: hook up a vat 40 to your battery w/inductive clamp around whatever wire.
3: hm, oh - have a partner crank the car while you read the amperage pull and battery voltage.
How do you know the battery is good?
When trying to start the car - what exactly happens? Does it crank and not turn over? Or does it clicK? .......need more info.
Old Dec 15, 2005 | 05:16 AM
flipwhip's Avatar
Default Re: (TheKINGPin)
Almost the exact same thing happened to me. I blew the fuse to my ECU. My battery and oil light both came on, and when i would turn the key, my car would act like it was trying to start but never would.
Old Dec 15, 2005 | 09:06 AM
onefastrx7turbo's Avatar
Default Re: (flipwhip)
Sounds like a bad ignition switch. theres a recall on them...
Old Dec 15, 2005 | 09:51 AM
OxYi's Avatar
Default Re: (onefastrx7turbo)
I think i did the ignition switch recall.
Fuse blow to the ECU..hmm maybe I will look into that.
When I try to start the car it would just crank and not turn over. The reason I said the battery is good because my battery die on me serveral time before, and the sound for that is clicking if I try to start the car, and also my light and radio were all working as well, so I think my battery is good ..
Could it be the distributor? since if it's bad then it won't be able to send spark to the cam. When I try to crank my car on, it just sound like it almost would start, but the last stage won't kick in
thanks guys
Old Dec 15, 2005 | 10:02 AM
OxYi's Avatar
Default Re: (OxYi)
ok it is the timing belt.... only the 3rd cam compression is a bit low..
525$ to fix
Old Dec 15, 2005 | 07:41 PM
Default Re: (OxYi)
3rd cam compression??
Old Dec 15, 2005 | 07:47 PM
H23 Power's Avatar
Default Re: (OxYi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OxYi &raquo;</TD></TR><TR><TD CLASS="quote">ok it is the timing belt.... only the 3rd cam compression is a bit low..
525$ to fix </TD></TR></TABLE>
$525 if all your valves are ok....
how much lower is the compression? if the timing belt breaks it usally takes some valves.
Old Dec 16, 2005 | 12:21 AM
OxYi's Avatar
Default Re: (H23 Power)
now i got the word back from the shop that it's my tensioner that broke, and he is changing the waterpump for me, and using the old timebelt, $517 for all..
Honda dealership quoted me $640 for all the belts(ac/timing/balance,etc + water pump)
I forgot whats the compression reading that he read to me, i think it was 185 for 1st, 2nd, and 3rd one is 170 or so, not so sure
Old Dec 16, 2005 | 12:44 AM
fastfu's Avatar
Default Re: (OxYi)
he going to use the old cam belt wtf
i'd pay the extra money and have honda do it ...PROPERLY
Old Dec 16, 2005 | 01:36 AM
littledan's Avatar
for real most likely ign switch recall my 97 has same prob i'm taking it in
Old Dec 16, 2005 | 05:33 AM
cullylude05's Avatar
dude in like 24k u will need to do the timing belt and be paying again for what u could just do now! more money do the belt now. i just got everything from the dealer i need to have my buddy help me do my timing belt, the waterpump(110), balance belt like 50 and timing belt was like (70) and valve cover was like (12) it all came to 252.00 all OEM
Old Dec 16, 2005 | 06:06 PM
JDmahmed's Avatar
How do you know for a fact that your battery is good? You think that the battery is still good after using it to recharge your vibrators for 20 hours straight? Speaking of which, your vibrator fetish is really sickening. The only thing worse than your fetish is your face and your shitty *** prelude. I wish you would rot in hell with that bitch you call your mom. expletive you and your life, ******!!!!!!!!
Old Dec 16, 2005 | 06:09 PM
Default Re: (JDmahmed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDmahmed &raquo;</TD></TR><TR><TD CLASS="quote">How do you know for a fact that your battery is good? You think that the battery is still good after using it to recharge your vibrators for 20 hours straight? Speaking of which, your vibrator fetish is really sickening. The only thing worse than your fetish is your face and your shitty *** prelude. I wish you would rot in hell with that bitch you call your mom. expletive you and your life, ******!!!!!!!!</TD></TR></TABLE>
Reported. Hope you get banned for that. Who the expletive are you anyway?.....
Old Dec 16, 2005 | 06:16 PM
JDmahmed's Avatar
King Pin, keep up the **** talk and I'll be forced to keep you and your mom away from my dick. I know your mom's all caught up on my Long Dong from Hong Kong, so she'll be mad as a bitch in heat if you expletive it up for her. Now calm the expletive down and get on yo knees...
Old Dec 16, 2005 | 06:47 PM
Yeah. :thumbs down:
I'm not going to get in an arguments with a mere child; however, if you DO have the ***** to settle this - come to GI or Nap and come see me. If not - i don't want to hear your ****. And yes - my mom loves the long dong. I'm glad you two are doing well. Son, this isn't middle school - "yo mama" jokes just don't cut it anymore.
You little ***** - don't forget, I'm <U>your</U> King - you have two options:
1: Get on your knees and kiss my feet
or
2: Get on your knees and suck my d*ck
Oh LOOK! You hit your 5 post/day limit. Damn.
KingPin: 1 LittleBitch: 0
Honestly, I wish I lived in Cali for a day. Oh boy.
So boy, are you coming to Gary, IN this weekend? I'll be waiting for you. Don't bitch up. C'mon - i'll make you bend over and grab your ankles you little expletive.
Old Dec 16, 2005 | 06:52 PM
To the poster - I apologize man. We have kids on this forum, and there's nothing we can do about it.
Old Dec 16, 2005 | 10:20 PM
ya look at me! im on dads computer! go eat **** JD
Old Dec 17, 2005 | 06:07 AM
shutta's Avatar
yeah anyways... i have a timing belt tensioner with all the hardware i'd sell you if you want to keep cost down. definatly replace the timing belt. $100 gets a greddy one that's real durable. that's what i'm using
Old Dec 17, 2005 | 08:37 AM
john d
Guest
Posts: n/a
Default Re: (OxYi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OxYi &raquo;</TD></TR><TR><TD CLASS="quote">only the 3rd cam compression is a bit low..
ughhhhhhhhhhhhhhh WTF?
Old Dec 18, 2005 | 01:01 AM
OxYi's Avatar
Default Re: (john d)
blah, it's done. My friend's dads shop went ahead and do the job... replaced the timing belt tensioner and waterpump for the total of $520...
The price is bad, but it's I can't pull out since it's a friend's shop..
anyway, my car is working again now,
but it is making this whinning noise like supercharger or something, could it be that the timing belt is too tight or the something ?
to TheKINGPin, it's cool man.
and to JDmahmed, STFU
Old Dec 18, 2005 | 05:43 AM
Whinning noise? Check power steering.........check belt also.
Old Dec 18, 2005 | 06:10 AM
mgags7's Avatar
the whining noise is most likely an improperly installed timing belt, whining on the edge of a gear or the tensioner pulley
take that ghetto sheit back to the shop and get new oem stuff.....do it right the first time....
ekillah
Aug 31, 2009 02:28 PM
4 door beast
Jul 15, 2009 08:13 PM
Arch-Angel
Jan 31, 2003 12:26 AM
RCautoworks
Jan 16, 2003 05:35 PM
