Strange noise after hitting the revlimiter in second gear
Old Dec 14, 2005 | 04:22 PM
90civichbsi's Avatar
Default Strange noise after hitting the revlimiter in second gear
first off, the setup in brief:
90 civic hatch
custom turbo kit
b16a1
Hondata s200
aem fpr
550cc's
walbro 255
msd sci w/ cap and blastercoil
Ok so the other day I was driving home and got on it in 2nd gear to redline and the tires spun a little so it bounced off the rev limiter for just a second then went part of the way through 3rd. After this my engine was making tinking sounds speratically. when i pushed the clutch (and let it just idle) it stopped. I got it the short distance home to check it out. when i rev (with the clutch pushed in) it sitting still it makes the noise every once and a while but not as much as when there is a load on the car. There are no check engine lights and it idles and runs fine (although im not driving it till i figure this out)
is this detonation? could the timing have gotten advanced somehow?
*POST has been edited the sound is not comming from tranny read post below too plz* thanks for the help
Modified by 90civichbsi at 6:39 AM 12/15/2005
Modified by 90civichbsi at 6:40 AM 12/15/2005
Modified by 90civichbsi at 6:41 AM 12/15/2005
Old Dec 14, 2005 | 05:25 PM
D-meet07's Avatar
Default Re: Strange noise after hitting the revlimiter in second gear (90civichbsi)
does it sound like it is coming from the tranny??
Old Dec 14, 2005 | 05:32 PM
nonvtecD's Avatar
If it's only when the clutch is out I would say it is tranny related although it seems strange it happened when you bounced the limiter. My tranny makes all sorts of awful noises and has for 6 months. I'm fixing it this week but if it is tranny related, hondas growl for a while before actually dying.
Old Dec 14, 2005 | 05:45 PM
onlinehost's Avatar
Default Re: (nonvtecD)
sounds like a throw-out bearing if you push the cluth in and the rattle goes away deffinatley a throw-out bearing
Old Dec 14, 2005 | 05:57 PM
CoreyR's Avatar
Default Re: (onlinehost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onlinehost &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a throw-out bearing if you push the cluth in and the rattle goes away deffinatley a throw-out bearing </TD></TR></TABLE>
yep.
Old Dec 14, 2005 | 06:00 PM
PnkRokCountryboy's Avatar
Default Re: (CoreyR)
how do you fix a throw out bearing?
Old Dec 14, 2005 | 06:02 PM
CoreyR's Avatar
Default Re: (PnkRokCountryboy)
replace it
Old Dec 14, 2005 | 06:20 PM
onlinehost's Avatar
you have to remove the tranny to do it so it would be a good time to check or upgrade your clutch
Old Dec 14, 2005 | 06:36 PM
komat's Avatar
input shaft bearing too
wont know until you pull it out
Old Dec 14, 2005 | 06:41 PM
onlinehost's Avatar
Default Re: (komat)
yea could be an input shaft but they usually make a squealing noise
Old Dec 14, 2005 | 07:04 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onlinehost &raquo;</TD></TR><TR><TD CLASS="quote">yea could be an input shaft but they usually make a squealing noise </TD></TR></TABLE>
they make clicking sounds
never heard them squealing
Old Dec 14, 2005 | 07:11 PM
onlinehost's Avatar
Default Re: (komat)
a pilot bearing making a clicking noise i have worked at norm reeves honda for 3 years and never heard one click to this day!
Old Dec 14, 2005 | 09:02 PM
Importordomestic's Avatar
knock knock... Who's there? a hole in the side of your block!! J/K sounds like you did something to your tranny
better than knock knock jokes
Old Dec 14, 2005 | 09:34 PM
Default Re: (Importordomestic)
no sorry i wrote that wrong... when i let it idle it stopped, when i push the clutch in and rev it it still makes the noise.
i just went out there and listened again and whats wierd is the ticking noise sounds like its comming from the exhuast manifold area.. it honestly sounds like a tiny rock hitting the inside of the metal on the manifold... weird... mebe unburnt fuel exploding in the manifold.
can the tial wastegate make noise like this out of boost?
Old Dec 15, 2005 | 04:35 AM
ccivic's Avatar
Default Re: (90civichbsi)
Wild idea, but maybe one of your bolts/studs snapped off and is lodged somewhere on the outside of your manifold or somewhere in your engine bay and it's jumping around.
Old Dec 15, 2005 | 06:02 AM
Default Re: (ccivic)
ive checked for anything loose on the outside but it really sounds like its comming from inside the manifold
Old Mar 19, 2006 | 09:09 PM
Pythagoras's Avatar
I encountered this exact same problem tonight. Bounced off the revlimiter and a few minutes later my car kinda lost a little power for a split second. Didnt think anything of it, pulled over, and got a very wierd grinding/ticking noise at idle. I drove up the road a 1/4 mile or so and the noise stopped. It reaccured in mild form a few more times on my drive home but always stopped when pushing in the clutch.
Old Mar 19, 2006 | 10:13 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">mebe unburnt fuel exploding in the manifold.
can the tial wastegate make noise like this out of boost?</TD></TR></TABLE>
hmm no and no.
sure its not your valves ticking? or maybe an exhaust leak?
Old Mar 20, 2006 | 07:09 AM
#1151's Avatar
Default Re: Strange noise after hitting the revlimiter in second gear (D-meet07)
check throw out bearing...a while back i remember that when i pushed the clutch in it would go away, but when i let out it started to knock...turns out one of the hooks that hold the bearign to the fork broke off and slaps/ticks when the clutch is released.
Old Mar 20, 2006 | 07:25 AM
USDM 4G VTEC's Avatar
trow out bearings only "whine" with the clutch put in
tranny bearings dont knock, but engine bearings do
none of us here will be able to tell you whats wrong....
just take it to a local shop and have them diagnose and tell ya whats wrong
Old Mar 20, 2006 | 07:35 AM
#1151's Avatar
Default Re: (USDM 4G VTEC)
really, so im lying when i said that it was my throw out bearing?...before you say anything, think about it. Car is idling. tranny not spinnng, clutch released. top hook is broken, and engine is vibrating. Bearing will move back in forth rapidly because of the vibration. Ohh, and when i replaced the bearing, guess what happened? went away completely.
Old Mar 20, 2006 | 08:10 AM
EM2Civic's Avatar
Pilot bearing and throwout bearing are the same thing. Most of the time when the bearing needs to be replaced you either hear it when the clutch isn't engaged, you can hear it rattle. But some ppl even chip their throwout (but that's mostly when you miss a downshift i.e. 4th to 2nd or 5th to 3rd).
Old Mar 20, 2006 | 12:14 PM
Got_soy's Avatar
Default Re: (EM2Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Civic &raquo;</TD></TR><TR><TD CLASS="quote">Pilot bearing and throwout bearing are the same thing. </TD></TR></TABLE> sorry bud, but thats not true, pilot bearings are housed in the center of the flywheel. The throwout bearing presses onthe fingers of the clutch plate.
Old Mar 20, 2006 | 12:39 PM
coneheadsracing's Avatar
Default Re: (Got_soy)
Stock rev limiter or soft touch. You may have hurt the engine... You could do a compression test, leak down test, pull the plugs, valve adjustment..... Pull the head Try spinning the motor by hand and see if you have any resistance at top dead.
QandA
Honda Civic (2001 - 2005)
Nov 17, 2012 06:26 PM
sauljhernandez
Nov 7, 2008 10:28 AM
gstrudler
Aug 29, 2008 10:45 PM
totsie7944
Mar 26, 2005 05:40 PM
