Greddy Timing belt for LS/Vtec Turbo Setup
Old Dec 14, 2005 | 01:58 PM
Topdawgg's Avatar
Default Greddy Timing belt for LS/Vtec Turbo Setup
Is there really a need to go with an aftermarket timing belt? Im shootin for 350-400 whp and Im wondering if i should go with a greddy timing belt...
any help would be greatly appreciated, and yes.. I searched the topic
Old Dec 15, 2005 | 02:58 AM
Topdawgg's Avatar
anyone?
Old Dec 15, 2005 | 05:32 AM
Pondus's Avatar
Default Re: (Topdawgg)
No need for it unless you run crazy NA cams, which I doubt you do on a turbosetup. OEM belt will do the job for you.
Old Dec 15, 2005 | 06:24 AM
Cprace1's Avatar
Default Re: (Pondus)
yep stock timing belt here no problems
Old Dec 15, 2005 | 06:29 AM
PRELUDE-GT35R's Avatar
Default Re: Greddy Timing belt for LS/Vtec Turbo Setup (Topdawgg)
If you go for SHOW than do it If not stick with STOCK
Old Dec 15, 2005 | 04:47 PM
Topdawgg's Avatar
Default Re: Greddy Timing belt for LS/Vtec Turbo Setup (PRELUDE-GT35R)
ok thanks guys.
any benefit with a TYPE R timing belt over GSR?
Old Dec 15, 2005 | 04:56 PM
LSVtechnologytur...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks guys.
any benefit with a TYPE R timing belt over GSR?</TD></TR></TABLE>
no, stock belts are stock belts. With ls/vtec you just have to make sure you have the right water pump & timing belt combo
Old Dec 15, 2005 | 05:53 PM
TurboCoop's Avatar
Default Re: Greddy Timing belt for LS/Vtec Turbo Setup (LSVtechnologyturboboost)
22 tooth water pump = vtec timing belt
19 tooth wp = non vtec timing belt
Ill save you some trouble
Old Dec 16, 2005 | 07:53 AM
Topdawgg's Avatar
Default Re: Greddy Timing belt for LS/Vtec Turbo Setup (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">22 tooth water pump = vtec timing belt
Ill save you some trouble </TD></TR></TABLE>
yea I read that in another thread...
vtec combo best for cooling...?
Old Dec 16, 2005 | 12:14 PM
im' not sure if they are any different. I think the reason it has a larger gear is because w/ vtec engines you rev higher..so if you were using a 19tooth gear your water pump would be flying by 8krpm.. so jumping up to a 22tooth it keeps the revolutions of the water pump lower because of the larger diameter gear.. and probably at a better speed.
. dont' quote me on that at all.. its just something i thought of
dc2LS
Dec 16, 2007 06:27 PM
faSHOwidIT
Feb 25, 2006 03:00 AM
faSHOwidIT
Dec 2, 2004 08:41 PM
xratedpres
Jul 27, 2004 06:29 PM
EFOSV
Jun 16, 2004 07:22 PM
