S200 bumpers
The AP2 headlight has a smaller footprint for the ballast. The AP1 ballast will fit with some mod. to the headlight. You should just seal the hole where the igniter enters the headlight, then mount the ballast to the framework. It saves cutting into the new headlight.
Bumper will fit.
Bumper will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">But the shape of the housing was unchanged? Thats mainly what i was talking about...as in how it lines up with the bumper itself...</TD></TR></TABLE>
correct ...
correct ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">Interesting...the slight changes on the inside of the housing really made it look like the whole thing was different. Thats pretty neat.</TD></TR></TABLE>
yup yup. only thing they did was change the ballast
Actually.. you're going to have a tiny gap between the headlight and the fender, no matter how much you adjust it. It will never fit like your OEM AP1 headlights.
u can retrofit the ap2 bumpers on ur ap1 with very lil work...the headlights of the 2 are same in shape but different in designs the ballasts are shaped differently as well to so to swap that out youll need to grind down the brackets to fit.
