16" wheels, what size tires
Old Dec 12, 2005 | 08:26 PM
zexifiedlude's Avatar
Default 16" wheels, what size tires
i wana ditch my 17's soon and get myself some 16" rota's. what size should the tires be.. right now on my 17's i have 215/40/17 .... i wanted to get 215/45/16 for the 16" wheels but parada's dont come in that size.. so what i need to know is, whats the usual size of tire people go with for 16 inch wheels?? ohh and the car is dropped about 1.5" front and back, give or take a little
Old Dec 12, 2005 | 08:46 PM
roller3804's Avatar
Default Re: 16" wheels, what size tires (zexifiedlude)
225-45-16 would be the tire to get. It will work great!
Old Dec 12, 2005 | 09:30 PM
shl76's Avatar
Default Re: 16" wheels, what size tires (camrann)
i have a 4th gen and here is my set up
225/45/16 front
205/50/16 rear
you can go 225's all around as well.
Old Dec 13, 2005 | 09:02 AM
bad-monkey's Avatar
215/45/16
225/45/16
Old Dec 13, 2005 | 09:08 AM
The Weather Man's Avatar
I'm going with 215/45/16.
Toyo Proxes baby
azenis cost too damn much.
Old Dec 13, 2005 | 12:15 PM
BrooX's Avatar
I think this would be an excellent discussion in the Wheel and Tire forum.
Old Dec 13, 2005 | 12:17 PM
Honda318dx's Avatar
Default Re: 16" wheels, what size tires (DA9GUY-637)
Moved
Old Dec 13, 2005 | 12:19 PM
nsxtasy's Avatar
H-T Order of Merit
What car model (Prelude?), version, and year do you have?
Also, what are you looking for in a tire? I.e. dry performance, wet performance, any snow use?, price, treadlife, etc. There are lots better tires out there than the Paradas, and some are better for the money, too...
Old Dec 13, 2005 | 01:04 PM
bad-monkey's Avatar
Default Re: 16" wheels, what size tires (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">What car model (Prelude?), version, and year do you have?
Also, what are you looking for in a tire? I.e. dry performance, wet performance, any snow use?, price, treadlife, etc. There are lots better tires out there than the Paradas, and some are better for the money, too...</TD></TR></TABLE>
all preludes have the same wheel/tire OD: 23.9"
Old Dec 13, 2005 | 02:36 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 16" wheels, what size tires (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">all preludes have the same wheel/tire OD: 23.9"</TD></TR></TABLE>
No, they don't.
For example, the 1988 Prelude came from the factory with 185/70-13 or 195/60-14 (outer diameter 23.2"). The 2000 Prelude came with 205/50-16 (24.1"). Heck, go all the way back to 1980 and they came with 175/70-13 (22.6").
Old Dec 13, 2005 | 02:40 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">No, they don't.
For example, the 1988 Prelude came from the factory with 185/70-13 or 195/60-14 (outer diameter 23.2"). The 2000 Prelude came with 205/50-16 (24.1").</TD></TR></TABLE>
yes yes you're right.
4th gens have a 23.9, 5th gens a 24.1, and the 3rd, 2nd, and 1st gens i don't know.
not that .2" is nothing, but its close enough to where you'd be buying the same size tires for either given the same rim size.
Old Dec 14, 2005 | 07:13 AM
i have a 99 prelude, and im looking for dry performance, not super bad treadlife would be good also, what tires would u recomend? im also trying to buy tires not over 120 a piece
Old Dec 14, 2005 | 07:49 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (zexifiedlude)
Thanks. Your car came with 205/50-16 tires from the factory.
For 17" wheels, your current 215/40-17 is fine (1.2 percent smaller outer diameter than stock) or you can get 205/45-17 (0.8 percent larger). Either size should work without problems.
For 16" wheels, the stock size should work fine. 215/45-16 will also work, but the outer diameter starts to be significantly smaller (1.9 percent) than stock, and tire availability is extremely limited. For both these reasons, I would probably stick with the stock 205/50 size rather than the 215/45, but it's your choice. As for the 225/45 size, which is significantly wider although slightly smaller (0.4 percent) than stock in diameter, that sounds like it might rub; I don't know. Tire availability in that size is also extremely limited.
For the factors you mention - dry traction, treadlife, and cost - I recommend one of these for the 16" wheels you're asking about, starting with the least expensive:
Kumho Ecsta SPT 205/50-16 $80 (from the Tire Rack)
Yokohama AVS ES100 205/50-16 $80 (from the Tire Rack)
Yokohama AVS ES100 225/45-16 $96 (from the Tire Rack)
If you want to spend a little more for better dry traction, consider:
Toyo T1-R 205/50-16 $103 (from onlinetires.com)
Toyo T1-R 225/45-16 $115 (from onlinetires.com)
For still better dry traction, consider:
Goodyear F1 GS-D3 205/50-16 $128 (from the Tire Rack)
These are IMHO the best tires for the money in each price category. As you can see, you can get better performance by spending a little bit more money for each step up in performance. But ANY of these tires will give you significantly better performance than the Paradas.
Old Dec 14, 2005 | 01:10 PM
^ hey thanks a lot bro
Old Jan 26, 2006 | 10:51 AM
Boofster's Avatar
Nobody likes the Fakens?
The RT-615 sounds pretty good...
Old Jan 26, 2006 | 03:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">Nobody likes the Fakens?
The RT-615 sounds pretty good...</TD></TR></TABLE>
Two problems with that idea:
1. It's yet not available in the larger 16" sizes to fit his Prelude. The only 16" size currently available is 205/40-16, which is good for older Civics, but is much too small for his Prelude.
2. He said that treadlife is an important consideration. Which rules out the RT-615, which wears faster than any other street tire.
Which pretty much rules it out on either count...
BMRALR
Feb 8, 2009 08:30 PM
B16Drag
Jan 26, 2004 07:09 PM
beaterman
Jan 15, 2004 07:28 AM
2000_Civic_Si
Mar 26, 2002 04:31 PM
HondaIntegraLS
Jun 27, 2001 07:43 PM
