95 Civic - Code 5 at idle?
Old Dec 12, 2005 | 03:55 PM
Powered By Garrett's Avatar
Default 95 Civic - Code 5 at idle?
Does this mean my map is shot?
Old Dec 12, 2005 | 06:48 PM
96dxpower's Avatar
Default Re: 95 Civic - Code 5 at idle? (Powered By Garrett)
https://honda-tech.com/zerothread?id=1171263 this may help
Old Dec 12, 2005 | 08:05 PM
No, I know what the code is hense why I asked if my MAP was shot (note, code 5 = MAP). But I was wondering what ABOUT my map it meant, because before I got code 3 (also map) in boost, and when i reset my ecu it would go away, this is on no matter what.
Old Dec 12, 2005 | 08:11 PM
Luserkid's Avatar
Default Re: (Powered By Garrett)
If your throwing code 5 from the start then your map is more then likely your problem. If you swap it out and still has this problem check the wiring.
Old Dec 13, 2005 | 09:16 AM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">If your throwing code 5 from the start then your map is more then likely your problem. If you swap it out and still has this problem check the wiring. </TD></TR></TABLE>
Okay, cool.
speedooo
11
Jul 24, 2008 09:27 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
racecarpete
Jan 15, 2005 08:55 AM
Intercooled JRSC
Oct 23, 2004 08:08 PM
