steady check engine light no codes
I have a 91 integra with a ls/vtec. I just converted it to obd1 the check engine light is on and i tryed to jump that little plug up in pass. floor but the light does not blink whats the deal. Im at a bit of a loss. When i start the car it idles really low like 500rpms for about 30 sec. then it Raise to 1000-1200 and the check engine light come on and i cant read a code what should i do.
went i shut the car off and i turn it back to were u start the car but not start it the check engin light is not on but i start it and it come on after a couple of minutes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dadriver »</TD></TR><TR><TD CLASS="quote">92-93 p72 gsr </TD></TR></TABLE>
Do you really believe this? Go to an auto parts store and have them scan the ECU for codes.
I just used my buddys p30 and i got the same thing so what do i do now I will just check the wirering for now tilll some one comes up with somthing good
I have the same problem but my light will blink the a KS code while the car is running without the jumper wire non-stop...i tried jumping the wire and it wouldn't do anything .....then it idled the same way...interesting.....I have wired vtec too so maybe one of my wires is run wrong or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dadriver »</TD></TR><TR><TD CLASS="quote">take the ecu out of the car and take it to and autoparts store?</TD></TR></TABLE>
Have an auto parts store connect to the scan port to diagnose the source of the CEL. It has to be in the car.
As far as i know there is no diagnostic port its an 91 integra Im about ready to tare the motor out and put the b18 so i could drive it
88crx Osaka
Aug 20, 2011 10:42 PM
