JDM front HID problems, need help
Old Dec 11, 2005 | 03:19 PM
Stunna BEN's Avatar
Don't call it a comeback
Default JDM front HID problems, need help
factory HID front end problems.
My bud was driving down the road and his passenger side headlight keeps cutting on and off. If he turns the light off, and turn it back on, the light comes on. When the light is turned on, it doesnt look like it warms up, it stays a blue color. After a min, it turns back off. He has had the front end since the beginning of summer, and this has just started this week. He is running the 20w fuses, as told to.
Any suggestions to this problem. Could it be grounding?
TIA
Old Dec 11, 2005 | 03:27 PM
six_speed's Avatar
the d2s bulb went bye bye.
Old Dec 11, 2005 | 03:29 PM
Stunna BEN's Avatar
Default Re: (six_speed)
Bulb is the problem?
Just making sure what the problem may be. Would hate to spend any more money than he has to.
Thanx for the reply. Anyone else with info?
Old Dec 11, 2005 | 03:40 PM
six_speed's Avatar
i had the same problem one time, and it would not stay on, it just flickers then turns off. i then went to investigate the problem, checking all the connections, and lastly checking the bulb to fine it had exploded.
Old Dec 11, 2005 | 03:49 PM
AntiStock's Avatar
The only time I had problems with my HID was when the battery was really low. One wouldn't light, and the other would just flicker. Once I charged the battery it was perfectly fine again. If you check the bulb and it's fine, make sure the connections are good and corrosion free because it might not be getting the power it needs to run them right.
Old Dec 11, 2005 | 04:05 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Default Re: (AntiStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiStock &raquo;</TD></TR><TR><TD CLASS="quote">make sure the connections are good and corrosion free because it might not be getting the power it needs to run them right. </TD></TR></TABLE>
Possiblility, But I'd say the bulb......
Old Dec 11, 2005 | 04:17 PM
migs's Avatar
Default Re: (01ITR#173DC2ning)
I would say the bulb and/or the ballast. I had an HID kit go out before and this is what it did.
Old Dec 11, 2005 | 04:44 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (migs)
usually when people retrofit, they just put in the + and - to the original harness.
This isn't good because when hot, hids need more juice to turn on and off.
You need to wire in a relay to supplement for the power
I think he just added positive and negative and added no relay which can be causing his **** to go off.
OEM Hids are suppose to last forever, I've never seen an hid bulb go bad, well I only used phillips ones so i really wouldn't know
Old Dec 11, 2005 | 04:45 PM
Padawan's Avatar
Darth ModerVader
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">I would say the bulb and/or the ballast. I had an HID kit go out before and this is what it did.</TD></TR></TABLE>
I agree, though ballast was the first thing that I thought of. It certainly wouldn't hurt to double-check all the wiring, and checking the capsule itself is a relatively simple matter (just swap the left and right capsules and see what the result is).
Old Dec 11, 2005 | 04:54 PM
98SpecR's Avatar
Default Re: JDM front HID problems, need help (Stunna BEN)
i had this problem also. unfortunatly it was my ballast, but i found someone who had only one. so i was lucky.
Old Dec 11, 2005 | 05:04 PM
Bradstard's Avatar
Ben, if you need a ballast give me a call tomorrow. I've got two ballasts sitting in my garage, neither are the OEM DC2R but they should work. One is an OEM TL and the other is an OEM 350Z. I'd sell one if you need it.
Old Dec 11, 2005 | 05:10 PM
T.J.'s Avatar
Default Re: JDM front HID problems, need help (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Ben, if you need a ballast give me a call tomorrow. I've got two ballasts sitting in my garage, neither are the OEM DC2R but they should work. One is an OEM TL and the other is an OEM 350Z. I'd sell one if you need it.</TD></TR></TABLE>
I know where those came from. I need to get my other kit back from Bryan
Old Dec 11, 2005 | 05:19 PM
Stunna BEN's Avatar
They are OEM. Let me see if he is in need
Old Dec 11, 2005 | 05:25 PM
T.J.'s Avatar
hey ben what kit is it . Is it the TL like we used to run?
Old Dec 11, 2005 | 05:26 PM
Stunna BEN's Avatar
Default Re: JDM front HID problems, need help (T.J.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T.J. &raquo;</TD></TR><TR><TD CLASS="quote">hey ben what kit is it . Is it the TL like we used to run?</TD></TR></TABLE>
No, he has the HID front from the 98up
Old Dec 11, 2005 | 05:33 PM
T.J.'s Avatar
ok need to try and narrow down the problem here. First thing he needs to do is switch out the two bulbs from the left and right side. If the problem continues on the side that was good when he switches the bulbs out then he knows he has a problem with the Bulb its self. After he does this and the problem continues to be the same. Tell him to check his wiring make sure everything is correct, and also properly grounded. After that if everything checks out then hes left with just the ballace, which is his problem and will have to be replaced.
Old Dec 11, 2005 | 05:35 PM
T.J.'s Avatar
also sorry for got to put this in but have him check his fuses and his relays.
Old Dec 12, 2005 | 04:49 AM
eeeKs's Avatar
Default Re: (Padawan)
swap the bulb over from left to right (or right ot left)
if the bulbs fine, then swap over the ballast
that should tell ya whether its the bulb or ballast
Old Dec 12, 2005 | 10:41 AM
98DC2-ITR's Avatar
We had an S2K here at our shop one time do something similar to this. It was simply a loose ground on the chassis harness near the rear of the headlight assembly. Check all your ground connections is my suggestion.....never know when one might have worked loose.
Old Dec 12, 2005 | 07:30 PM
[Ennis_D]'s Avatar
Default Re: JDM front HID problems, need help (98DC2-ITR)
First off I would like to thank Ben for taking time out of his schedule to take my call, listen to my problem, discuss some possibilities with me, and then make a thread to get some other input! Mad props! Next, I would like to thank everyone that posted some input on what the problem could be and some ways to make sure what the problem really was! You guys were very helpful!
Came home today after talking to Ben again and decided that I needed to get to the bottom of this problem. I figured that the easiest thing I could do first would be to test the ballast. So I unhooked both ballast and used female connectors to run a power and ground wire out of the male driver side ballast plug...the plug that had the power and ground for the ballast itself. Ran the ground, turned the lights on, and touched the power to the female plug for the passenger side headlight. And sure as the world, the passenger side headlight came on, warmed up the the color it should be and imediately changed to a pinkish-purple color. About 15-20seconds after that, it started flickering. When the flickering began, it took the bulb about a minute and a half to completely cut off. I tested the passenger side bulb on the driver side ballast about three times and had the same results each time. Also, I checked the passenger side ballast on the driver side bulb and that bulb worked fine showing me that the passenger side ballast was good!
All in all, after reading all the input and taking ideas from what Ben had given me along with you guys, I found out that the passenger side ballast is good but I need to replace the bulb...Looks like I will be making a trip to the Honda or Acura dealership for a new D2S bulb here in the next couple of days...Which brings me to another question...Does anyone happen to know if the S2Ks use a D2S bulb? I believe that the TSX and TL do but I live right down the road from the Honda dealership so I was going to try to save some gas a time and run up there and grab a S2K bulb. If they dont use a D2S bulb but the TSX and TL do, does anyone know the part # for them so I can just go to Honda and order that part number?
Once again I would like to think Bizzle and everyone else that has given me input and ideas on what I need to do in order to get to the bottom of this problem! Thank God for H-T! Merry Christmas and Happy Holidays!
Old Dec 17, 2005 | 06:18 PM
T.J.'s Avatar
Default Re: JDM front HID problems, need help (Trock1029)
were you able to find the correct bulb yet?
Old Dec 17, 2005 | 06:43 PM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiStock &raquo;</TD></TR><TR><TD CLASS="quote">. If you check the bulb and it's fine, make sure the connections are good and corrosion free because it might not be getting the power it needs to run them right. </TD></TR></TABLE>
Make sure the ballast isn't wet too. Also check thr grounds(I'm not sure how the hook up on JDM front ends)
Old Dec 17, 2005 | 06:54 PM
Addicted2Racing's Avatar
YES, all HID projectors uses D2S and none projectors uses D2R. G/L
kroze
Lighting
Apr 28, 2009 06:47 PM
EJ6_Sedan
19
Nov 21, 2007 10:21 PM
simriv123
Jul 16, 2007 07:51 PM
Devine
Nov 28, 2005 02:31 PM
