99 Integra HELMS manual
Old Dec 10, 2005 | 09:06 PM
Integra Integra's Avatar
Default 99 Integra HELMS manual
I am in desperate need of a site that has a helms manual online or even some other thing similar to a HELMS guide, I need to know torque specs for a few things. If it isn't free I can pay on a site or w/e
Thanks!
Old Dec 10, 2005 | 09:10 PM
Micha's Avatar
FAILWGN
Default Re: 99 Integra HELMS manual (Integra Integra)
Just go to helmsinc.com I believe. What do you need torque specs for? Maybe I can get them for you in the morning after I wake back up.
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Type R FAQ &raquo;</TD></TR><TR><TD CLASS="quote">Torque Specs:
https://honda-tech.com/zerothread?id=687580 - Header/Bracket&lt;---&gt;Cat&lt;---&gt;Exhaust
https://honda-tech.com/zerothread?id=648853 - Wheel Lug Nut - 80 Lbs/Ft (Tighten in Criss Cross - Five Star Pattern)
https://honda-tech.com/zerothread?id=636000 - Intake Manifold - 18 Lbs/Ft
https://honda-tech.com/zerothread?id=143407 - Front Strut Bar - 17 Lbs/Ft
https://honda-tech.com/zerothread?id=391531 - Spark Plugs - 13 Lbs/Ft
https://honda-tech.com/zerothread?id=562177 - Spindle Nut - 134 Lbs/Ft
https://honda-tech.com/zerothre...91836 - Oil Pan Drain Bolt - 33 Lbs/Ft
https://honda-tech.com/zerothread?id=232140 - Transmission Filler Bolt - 33 Lbs/Ft, Drain Bolt - 29 Lbs/Ft
https://honda-tech.com/zerothread?id=317728 - Oil Filter - 7/8th Turn Clockwise or 16 Lbs/Ft
Not sure if this will help or not, but this was taken from the faq in the type r forum. You could also just list what you need the torque specs for and someone witht the manual could probably look it up for you.
Ali
Old Dec 10, 2005 | 09:14 PM
Default Re: 99 Integra HELMS manual (PrinceAli132)
Well I am gonna change my head gasket so I need those specs and I have the specs for my timing belt + water pump from Team Integra. Is there like a site that I can pay that I can have access to there page or an ebook possibly?
Thanks!
Old Dec 10, 2005 | 11:24 PM
dynamo's Avatar
http://www.hondahookup.com/manuals/
Old Dec 11, 2005 | 01:36 AM
RaceMyGhost's Avatar
http://www.redpepperracing.com
Old Dec 11, 2005 | 05:45 AM
Default Re: (RaceMyGhost)
Are torque sizes the same for the 1994 Integra as they are on the 1999 because I downloaded the guide for the 1994 service guide and they dont have 1999
Thanks
Old Dec 11, 2005 | 08:06 AM
Phoenix_ITR's Avatar
Default Re: (Integra Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra &raquo;</TD></TR><TR><TD CLASS="quote">Are torque sizes the same for the 1994 Integra as they are on the 1999 because I downloaded the guide for the 1994 service guide and they dont have 1999
Thanks</TD></TR></TABLE>
torque specs should be the same.
Old Dec 11, 2005 | 08:09 AM
Default Re: (Phoenix_ITR)
Thanks!
Old Dec 11, 2005 | 09:51 AM
00IntegrAllmotoR's Avatar
HT Black OPs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">http://www.redpepperracing.com</TD></TR></TABLE>
thanks for that page, i needed that and its free!
2toneteggy
Sep 27, 2008 11:26 AM
tsjeff
Oct 28, 2003 05:52 PM
ryu12341
Apr 17, 2003 12:25 PM
WangChung
Mar 29, 2003 03:13 PM
B18aTegra
Aug 20, 2002 10:42 PM
