swap problems
Old Dec 10, 2005 | 08:55 AM
blkhatch97's Avatar
Default swap problems
I have a 97 hatch with a jdm b16, I used the harness & ecu p2t obd2 that came with it but it wont pass emissions so i bought an si ecu usdm & harness it doesnt have all of the plugs to go in the ecu i did this on my own and I need help!!!!
Old Dec 10, 2005 | 09:30 AM
Kendall's Avatar
I believe you'll be needing an OBD-2A to OBD-2B conversion harness.
Old Dec 10, 2005 | 03:11 PM
blkhatch97's Avatar
Default Re: (Kendall)
will that make up for the missing plug? and make it pass emissions ?
Old Dec 10, 2005 | 03:22 PM
Slopoke's Avatar
Default Re: swap problems (blkhatch97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhatch97 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 hatch with a jdm b16, I used the harness & ecu p2t obd2 that came with it but it wont pass emissions so i bought an si ecu usdm & harness it doesnt have all of the plugs to go in the ecu i did this on my own and I need help!!!!</TD></TR></TABLE>
You cant use the '99-'00 si engine harness in your car '97.
Old Dec 10, 2005 | 03:35 PM
blkhatch97's Avatar
Default Re: swap problems (Slopoke)
so what harness 97 ex if so what ecu? i heard a 96-?? del sol but i'm not sure??????
Old Dec 10, 2005 | 05:36 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhatch97 &raquo;</TD></TR><TR><TD CLASS="quote">so what harness 97 ex if so what ecu? i heard a 96-?? del sol but i'm not sure??????</TD></TR></TABLE>
Yeah, I think you want to find a obd2A usdm b16 ecu. Wich I think your best option is a del sol ecu. They are probably pretty hard to find, though.
Another option, might be to get a vafc and lean it out before you take it to get tested.
Old Dec 10, 2005 | 05:45 PM
blkhatch97's Avatar
I would get a vafc and do that but here they just plug in there comp to yours and checks for codes!!! thanks !!
TK_209
Oct 8, 2009 12:38 PM
savestheday13x2
16
Feb 1, 2005 06:36 AM
ShowtimesDC2
Jul 24, 2003 01:00 PM
Ehron
Aug 1, 2002 07:10 AM
