bouncing idle 800rpm to 2500rpm
Old Dec 9, 2005 | 11:34 PM
90AcuraIntegra04's Avatar
Default bouncing idle 800rpm to 2500rpm
Okay i can not seem to figure out my problem. I start my car and immediately it stats bouncing from 2k to 800 back to 2k then 800 over and over. I rev it and it does the same thing. I asjust the idle screw and it only makes it idle faster. All vaccum lines are good. I disconnected the tps and it stopped the reving but idled at 2500-3000 rpms, i dont even have to give my car gas to get going which is not good. What is causing my problem? thanks
Old Dec 10, 2005 | 12:38 AM
watsvtecEK's Avatar
Default Re: bouncing idle 800rpm to 2500rpm (90AcuraIntegra04)
maby the ignitor in the dizzy? i havd a simular problem i think. my tach would start to tweak out when i brang it to about 5k. dose your idle seem to be jumping? or is it just the gauge acting weard? it the idle rough?
Old Dec 10, 2005 | 09:17 AM
the idle is rough itself, the tach shows it properly bouncing.
Old Dec 10, 2005 | 09:29 AM
LL2009's Avatar
Default Re: (90AcuraIntegra04)
try changing you pcv valve , when it goes bad you idle goes crazy.
Old Dec 10, 2005 | 10:38 AM
integra95gsr's Avatar
tps sensor by chance?
Old Dec 11, 2005 | 03:00 PM
IOSUA's Avatar
check your IACV (idel air control valve). maybe it got dirty. take it off and clean it out with carb cleanner. Check your TPS (throttle position sensor) mabye it gone bad or it might be broken. i had the same problem and it was my TPS. check your check engine code before you do all that. it will help.
Old Dec 11, 2005 | 04:08 PM
Chubz's Avatar
Default Re: (jdm dc2 01)
definitly check the IACV, TPS sensor should output readings of .45 closed and 4.5 at wide open throttle, obviously dont test those reading with the motor running
Old Dec 11, 2005 | 05:26 PM
RalliartRsX's Avatar
Default Re: (Chubzilla)
By the looks of it, you have a 1990 teg, correct?? This is a common issue with these cars. Here is some info that might help
http://g2ic.com/forums/showthread.php?t=35534
http://g2ic.com/forums/showthread.php?t=44386
Check those first as it seems those are the main culprits.
mikeunreal2
11
Mar 23, 2006 12:00 PM
225DC2GSR
Jun 22, 2005 10:42 AM
CRX-SIR
Sep 20, 2004 06:00 PM
SLOAZZ95
Nov 5, 2003 04:42 PM
chirp2hrd
Oct 13, 2002 01:36 AM
