Burning Oil!!
I have been losing oil at a rate of about 1/2 a quart every two tanks of gas (~550-600mi.). I checked my engine bay and fixed all the exterior leaks: cam plug, valve cover gasket. I've done a leak down and no major pressure drops. My compression is 150, 150, 150, 140; a little low but even. I can't see any smoke coming out of my tail pipe either.
I'm stumped!!!
Any other suggestions?
Any advice will be greatly appriciated.
Thanks,
Joe
I'm stumped!!!
Thanks,
Joe
umm...have you checked your oil pan? do you see any oil on the ground when you leave a spot after parking a while? you could be burning oil just because the car is old. how many miles on it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supadupamikey »</TD></TR><TR><TD CLASS="quote">1/2 qt every 600 miles isn't bad...
im burning 1-2qts every 100-150 miles...
I have 140K on my GSR and burn NOOO oil between oil changes. I used synthetic oil during the whole life of the car and 3k intervals.
maybe you abused your engine and didnt maintain it properly.
most likely its the pistons rings
have a leak down test done
dont feel bad i have 13,000 miles on mine and it burns about the same amount as you. just always keep oil in the trunk and check it every time u get gas
blacktibby07
Feb 13, 2011 09:50 AM
