engine oil low
Old Mar 17, 2007 | 01:26 PM
IntegraRules!'s Avatar
Default engine oil low
I had the ITR engine oil running low in less than 2 months of oil change...last time there were leaks from oil and cams seal so got that replaced and taken care of...now it's not too bad but i'm suspicious there may be other leaks or burning oil?? I got new JDM pistons in there about 5 months ago...any suggestion what to look for?
Old Mar 17, 2007 | 01:57 PM
vtec.dc2's Avatar
Default Re: engine oil low (IntegraRules!)
if you don't see any leaks outside the engine (oil pan, headgasket, valve cover, oil filter, stock pressure sensor or anywhere oil can run out) then its getting inside combustion chamber.
blue smoke = oil.
how much oil do you loose in between oil change or in that 2 month period?
how many miles driven during that time?
Old Mar 17, 2007 | 11:30 PM
jus daily driving and i probably added in a litre of oil with less than 3k between those two months for sure...no oil leak anywhere visible or on the ground in my garage. I had Mugen catback in my ITR and the smoke stinks but no different in colour though.
Old Mar 18, 2007 | 08:46 AM
nsxtasy's Avatar
H-T Order of Merit
One quart/liter of oil consumed in 2-3K miles is common.
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
highwhey
Nov 11, 2010 05:53 AM
bopbop93030
Jan 11, 2010 02:59 PM
digitalayon
Mar 13, 2005 07:55 AM
tensai717
Dec 9, 2001 03:49 PM
