Smoking B16a
Old Dec 8, 2005 | 10:44 PM
sir2sol's Avatar
Default Smoking B16a
Ok for about a year now i've had big problems with my beloved b16a, but i think now i've finally found the problem. i just rebuilt my motor and put .025 overbore ctr pistons in it. but still it smokes. i've had compression checks and leakdown tests done and both come back good.
i've got bluish/white smoke coming out the exhaust pretty much all the time and have noticed that the valve cover is insanely hot but the motor never really overheats. i've got a little bit of oil leaking around the head and block. my conclusion is that the head is warped. i know, i know, i should've had the head milled a little bit when rebuilding the motor but i didn't think of it.
I'd appreciate everyone else's $.02. tell me if i'm crazy thinking it could be that or not.
Old Dec 9, 2005 | 04:18 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Smoking B16a (sir2sol)
change you pcv valve then your valve guide seals if necessary
Old Dec 13, 2005 | 11:18 AM
sir2sol's Avatar
Default Re: Smoking B16a (PURPLETERROR aka BIGMATT)
i've notice the last couple of times i've driven it, that i can't really see any smoke, but then again it is winter so i might be confusing smoke with steam, but i can smell oil burning. i've checked the oil level, but it's not really changed. could a warped head cause oil as well as coolant to leak into a cylinder too?
Old Dec 13, 2005 | 10:17 PM
FairlightRacing's Avatar
Possibly. You would have oil coming down, running across the head-gasket and dropping in to the combustion chamber. Then you would have water (well probably steam actually) making its way up past the head-gasket in to the combustion chamber.
Voila! A nice bluish-white smoke plume.
Old Dec 14, 2005 | 09:56 AM
sir2sol's Avatar
Default Re: Smoking B16a (FairlightRacing)
that's pretty much what i've got. i light bluish/white smoke out the exhaust. not really a "heavy" blue smoke, just real light and wispy. i've had an idea that this problem might be caused by a warped head , but at least now i've got a solid idea to go on.
Old Dec 14, 2005 | 12:09 PM
Ls5000's Avatar
you might have a guide problem. Does it only smoke for a couple of seconds when you turn it on???
Old Dec 17, 2005 | 03:51 PM
sir2sol's Avatar
Default Re: Smoking B16a (Ls5000)
naw, this mug smokes all the time. i'm planning on taking the head off this week and take it to have the head shaved, if need be. even if this isn't the problem i figure it wouldn't hurt to start narrowing down.
Old Dec 17, 2005 | 04:41 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">change you pcv valve then your valve guide seals if necessary</TD></TR></TABLE>
exactly what i was going to say
Ls-v Da Teggy
Mar 26, 2014 08:22 PM
slaquers
Engine Management and Tuning
Jul 24, 2011 10:14 AM
si 2
May 8, 2010 10:16 AM
importfan28
16
Oct 9, 2006 06:07 PM
Shark Tank
Oct 27, 2002 11:24 AM
