gsr swap into ek
ok i have a 98 ex coupe and i just bought a obd1 gsr swap from hmotorsonline what else do i need besides a 0bd2<obd1 adabter. Like what mounts and i want to keep my ac.
look on http://www.hasport.com
i believe stock mounts work, you just need a rear tranny mount from a 99-00 si and a del sol ac bracket i believe. but yea double check with hasport, it's on their website.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout »</TD></TR><TR><TD CLASS="quote">look on http://www.hasport.com
i believe stock mounts work, you just need a rear tranny mount from a 99-00 si and a del sol ac bracket i believe. but yea double check with hasport, it's on their website.</TD></TR></TABLE>
Correct. Also a shiftlinkage and axles if didn't come with the swap.
HASport does still offer an upgrade kit, though the stock mounts will work (which we offer).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">
HASport does still offer an upgrade kit, though the stock mounts will work (which we offer).</TD></TR></TABLE>
You need the timing belt side bracket for the '99-'00 si. (its the bracket that sits between the mount that bolts to the block and the rubber fluid filled mount).
Then reuse your stock civic upper tranny mount.
ANGELIQUE
Mar 15, 2005 12:25 PM
