HELP: Just put in new motor and....
Old Mar 15, 2002 | 02:16 AM
CivicEK.PDX's Avatar
Default HELP: Just put in new motor and....
I just swapped in my new motor. Anyways...I pulled it out to take it for a spin.....and I get down the block...shift into 2nd and it stops working. Also now that it dont move....when I step on the gas the speedo kinda climbs also. SOMEONE PLEASE HELP . Thanks
Old Mar 15, 2002 | 05:42 AM
DC2_R's Avatar
Default Re: HELP: Just put in new motor and.... (CivicEK.PDX)
When you step on the gas does it move at all? Does it go into gear and still doesn't move? Engine runs but doesn't move? Check axles to make sure that one didn't pop out. I had that problem just recently. Hope that helps. Where in Portland are you from exactly? I used to live in Boring, Gresham, Clackamas, and Wilsonville. Send me an IM, well talk
Old Mar 15, 2002 | 06:03 AM
Kamin's Avatar
Default Re: HELP: Just put in new motor and.... (JDM_EJ)
check your other post.
Old Mar 15, 2002 | 12:42 PM
Ya......exactly like you said......I am gonna check my axles today. Also I in in Portland
Old Mar 15, 2002 | 02:04 PM
DAMMIT........it was the axle.....pulled it and it was sitting out about 1.5 inch. About 2mm was taken off the inboard part. Diff looks fine( found some metal shaving.......but wiped them out......but it looks fine) just the splines on the axle are gone about the ring. Waiting for axle right now.....and gonna give the tranny a fluuid change.
yblegal
Dec 21, 2010 09:25 AM
ID_ten_T
Jan 12, 2004 07:08 PM
5 Skware
Aug 28, 2003 05:13 PM
5 Skware
Aug 28, 2003 05:12 PM
CivicEK.PDX
Mar 15, 2002 04:01 PM
