Necessary for flywheel to be resurfaced?
Old Dec 8, 2005 | 12:10 PM
bebfsu1's Avatar
Default Necessary for flywheel to be resurfaced?
One of my buddies is replacing the transmission on his car. Is it necessary for the flywheel to be resurfaced? He's kinda short on money and needs to know if he can get by without doing it.
Old Dec 8, 2005 | 12:13 PM
BauleyCivic's Avatar
Risky Business
Default Re: Necessary for flywheel to be resurfaced? (bebfsu1)
It is not necessary. However, the clutch will wear out much faster if you don't.
Old Dec 8, 2005 | 12:42 PM
Luserkid's Avatar
Default Re: Necessary for flywheel to be resurfaced? (BauleyCivic)
If its a new clutch then do it. Its only like 40 bucks tops. If its the same clutch he was running before then hell be fine.
Old Dec 8, 2005 | 12:59 PM
Tony_EM1's Avatar
Default Re: Necessary for flywheel to be resurfaced? (Luserkid)
its like 19 bucks dude ... i would do it
Old Dec 8, 2005 | 01:09 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Necessary for flywheel to be resurfaced? (code415)
The money should not be an issue. If you take the flywheel to the shop, it should be VERY cheap (should be less than $40).
As BauleyCivic said, it will wear on your clutch disc more than average. It's similar to resurfacing the brake rotors when you replace the pads. The new pads won't sit perfectly with the rotors and there will be uneven/not normal wear.
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
VtecCivic93
Mar 25, 2008 07:36 PM
rukawa1one
Feb 21, 2006 06:13 PM
civcexcoupeblack
May 9, 2003 01:35 AM
Dirty GS-R
Feb 5, 2002 05:08 AM
