OBD2 + Straight pipe = lean??
correct me if im wrong, but if theres a obd 2 car with a striaght up with a stock ecu, will the same reading, which cuases it to try to fix it by making my a/f mixture more lean....??
ill take that as a yes
took out my plugs last night, they are extremely FROSTY. would it be more safe to run a p28 (virgin) on an em1 w/ a straight pipe or just F it and put my cat back??
no it wont be lean dude. your check engine light will come on tho because the secondary post o2 will not be getting a good reading. A test pipe is for better flow, less restriction. Ths secondary o2 is for catalytic effeciency. so since you have a straght pipe it wont get any reading at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">no it wont be lean dude. your check engine light will come on tho because the secondary post o2 will not be getting a good reading. A test pipe is for better flow, less restriction. Ths secondary o2 is for catalytic effeciency. so since you have a straght pipe it wont get any reading at all.</TD></TR></TABLE>
this is why you need to get your p28 chiped...it doesnt care about the 2nd o2 sensor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila »</TD></TR><TR><TD CLASS="quote">actually, its been running VERY lean.
do you have a wideband and can prove this? yes it runs lean under most conditions but when you go into vtec im sure like most honda's it runs very rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">I think his plugs prove that it was lean when he killed the motor.</TD></TR></TABLE>
that sucks...
that sucks...
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
