ignition coil????
Old Mar 14, 2002 | 07:35 PM
phildeez's Avatar
Default ignition coil????
Hello
I was driving yesterday and my car stalled while i was rolling up to a red light. I tried to restart it and it wouldn't turn over. I towed it home and replaced the ignition coil and then it started right up! Today I drive around for a little bit and then go home it sat for about an hour then i tried to start it up again and it wouldn't turn over. WTF? Can anyone help me on this? can it be the ignitor?
thanks
Phil
Old Mar 14, 2002 | 07:36 PM
fixhondas's Avatar
Default Re: ignition coil???? (phildeez)
do you have spark? What brand of coil did you use? Coils burn out for a reason- did you replace your cap rotor and plugs to prevent the new coil from burning out?
Old Mar 14, 2002 | 07:40 PM
phildeez's Avatar
Default Re: ignition coil???? (fixhondas)
No i didn't i just took a coil from an extra distributor i had laying around. I did change the spark plugs tho.
Before i towed the car i pulled the spark plug out and connected it to the wire and tried to start, but i didn't see any spark.
I had a Jacobs ice pak in the car a week before. then this happened.
the car is turboed.
How much is the cap and rotor? and why would the coil burn out?
sorry i don't know much about this ignition stuff...i should...thanks
Old Mar 14, 2002 | 07:43 PM
fixhondas's Avatar
some car info would be helpful here
Old Mar 14, 2002 | 07:46 PM
phildeez's Avatar
ohh sorry.
its a 92 prelude JDM F22B non vtec
5-7 psi boost
2nd gen eclipse manifold
2nd gen eclipse turbo and intercooler
b n m fuel press regulator
stock accord pistons 8.1:1
12:1 vortech fmu
NGK 7r plugs
and stock every thing else.
Old Mar 14, 2002 | 07:50 PM
fixhondas's Avatar
so you have no spark? Check for pulsing ground on the coil negative terminal while cranking. If you have no pulse- it is most likely your igniter. (Especially if it is an OKI igniter- brown or black- OKI igniters are trash).
Old Mar 14, 2002 | 07:52 PM
phildeez's Avatar
cool, ill check that... so i should replace the cap, rotor and igniter...right??
I'll do that and keep you updated. thanks for the help man. that was fast.
Old Mar 14, 2002 | 07:54 PM
fixhondas's Avatar
A new cap and rotor is a good idea if your coil burns out- however- you can check the igniter instead of simply replacing it- if you replace it- be sure to squeeze the terminals with pliers before pushing them on or they won't be tight
Old Mar 15, 2002 | 04:38 AM
td04civic's Avatar
check your module. mine went right after my coil.
Old Mar 15, 2002 | 07:22 PM
phildeez's Avatar
Default Re: ignition coil???? (td04civic)
I had my mechanic replace the igniter and coil. but i haven't put the distributor back in yet. im at work
after the car didn't start yesterday i came home about 5 hours later and tried to start it again and it started right up! do you guys think that is the igniter?
spoonhbk11
11
Jun 9, 2019 07:03 PM
hey man
Dec 22, 2010 06:59 AM
gottagofaster
Oct 21, 2005 11:58 PM
