what causes back fire?
Old Dec 6, 2005 | 11:18 PM
gray_civic_coupe's Avatar
Default what causes back fire?
I noticed back fires when I hit the race, why this is happening?
Old Dec 6, 2005 | 11:20 PM
komat's Avatar
Default Re: what causes back fire? (gray_civic_coupe)
you mean gas??
stock engine with basic bolt ons??
if so most likely the donut gasket on the header is leaking or the cat gaskets
Old Dec 6, 2005 | 11:31 PM
EJAYATE's Avatar
I Deliver
Im really confused
Old Dec 6, 2005 | 11:41 PM
its stock with bolt ons
and yes when i floor the gas
the car started to get fucked up !!
I fix something and another issue pops up, I started hating my car and thinking of selling it.......
Old Dec 7, 2005 | 12:06 AM
Default Re: (gray_civic_coupe)
bump
Old Dec 7, 2005 | 04:12 AM
BUMP...............
Old Dec 7, 2005 | 05:19 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gray_civic_coupe &raquo;</TD></TR><TR><TD CLASS="quote">its stock with bolt ons
and yes when i floor the gas</TD></TR></TABLE>
So when you're on the gas, it's backfiring? If that's the case, i'd check the timing.
Old Dec 7, 2005 | 05:50 AM
IHateJDM's Avatar
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
It shouldn't backfire while accelerating. If it backfires between shifts, that's common.
Old Dec 7, 2005 | 01:18 PM
The timing belt is not in a good condition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
It shouldn't backfire while accelerating. If it backfires between shifts, that's common.</TD></TR></TABLE>
when i remove my feet from the gas pedal it backfires.
Old Dec 7, 2005 | 02:22 PM
AutoXer's Avatar
You should change it ASAP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gray_civic_coupe &raquo;</TD></TR><TR><TD CLASS="quote">when i remove my feet from the gas pedal it backfires.</TD></TR></TABLE>
That's fairly normal. Caused by unburnt fuel and backpressure in the exhaust system. Not much you can do about it.
Old Dec 9, 2005 | 05:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">You should change it ASAP.
I will
boongley29
Acura TSX
25
Sep 19, 2007 01:52 PM
npor
Dec 7, 2006 09:19 PM
spoonef
Jun 25, 2005 06:13 AM
xunkn0vvnx
Mar 30, 2005 05:33 PM
RnEpmc
Jul 11, 2004 01:28 PM
