what causes back fire?
Re: what causes back fire? (gray_civic_coupe)
you mean gas??
stock engine with basic bolt ons??
if so most likely the donut gasket on the header is leaking or the cat gaskets
its stock with bolt ons
and yes when i floor the gas
the car started to get fucked up !!
I fix something and another issue pops up, I started hating my car and thinking of selling it.......
Re: (gray_civic_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gray_civic_coupe »</TD></TR><TR><TD CLASS="quote">its stock with bolt ons
and yes when i floor the gas</TD></TR></TABLE>
So when you're on the gas, it's backfiring? If that's the case, i'd check the timing.
Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">
It shouldn't backfire while accelerating. If it backfires between shifts, that's common.
Re: (AutoXer)
The timing belt is not in a good condition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
It shouldn't backfire while accelerating. If it backfires between shifts, that's common.</TD></TR></TABLE>
when i remove my feet from the gas pedal it backfires.
You should change it ASAP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gray_civic_coupe »</TD></TR><TR><TD CLASS="quote">when i remove my feet from the gas pedal it backfires.</TD></TR></TABLE>
That's fairly normal. Caused by unburnt fuel and backpressure in the exhaust system. Not much you can do about it.
Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">You should change it ASAP.
I will
I will
RnEpmc
07-11-2004 01:28 PM
