Question on interchangable brake parts - eg/teg
I have a 93 SI, and have a ton of 94->teg brake parts laying around.
So my questions is, using my SI suspension and hub, what would it take to use teg disc brakes/calipers (have those too)? If/can I bolt the teg disc on to my hub, and then how different if the teg caliper mounting (bracket?)?
Ive done a bunch of searches here, the suspension, and teg forums.. and havent come up with anything good.
btw, Ill do a How To w/ a ton of pics once/if I can do this.
TIA.
TIA.
The rear brake setup is the same rotor size and caliper piston size. The only difference will be the Rear Hub and Sensor, if the 94 Integra has ABS. I am unsure as to whether ABS Rear Hub/Spindle is the same diameter as non-ABS.
The front brake setup for the 94 Integra uses a larger rotor than the 93 Civic SI. You'll need the Knuckle/Bearing/Hub assemblies from the Integra to use them. I think I remember reading about problems using DC Knuckles on an EG, but I'm not sure... Use the Integra Calipers (it has a bigger piston) as well. If you change your Hydraulics (by using a bigger piston), you might need to also get a new Brake Booster and/or Brake Master Cylinder. Do some more digging, and you'll find what you need.
Interchangeable parts:
https://honda-tech.com/zerothread?id=1024818
Knuckle Shuffle:
https://honda-tech.com/zerothread?id=1351181
https://honda-tech.com/zerothread?id=1318681
https://honda-tech.com/zerothread?id=1351209
The End:
https://honda-tech.com/zerothread?id=152884
Have fun!
JasonGhostz... (Use the upper right, Luke!)
Knuckle Shuffle:
The End:
Have fun!
michael_fernz
Jul 10, 2009 05:22 AM
6shootahorsenamedtrigga
May 11, 2006 12:11 PM
hondahans
Jan 27, 2004 03:33 PM
