turbo problems please help
Old Dec 6, 2005 | 02:04 PM
98redDXturbo's Avatar
Default turbo problems please help
i have a d16y7 with a td04h turbo set up on it fmu ,injectors,plugs,retarded timingand i have two problems one my oil smells like gas and two when i hit 6 pounds of boost the car stutters and drops boost to 5 then it pulls again i have the missing link for the map sensor so i know its not that i would appreciate any help you can give
Old Dec 6, 2005 | 02:15 PM
platinum00's Avatar
Default Re: turbo problems please help (98redDXneedsAheart)
has the car ever run right with boost?
you need the right FMU or some engine management.
the forced induction forum would be better
platinum.
Old Dec 6, 2005 | 02:18 PM
Default Re: turbo problems please help (platinum00)
well on the first motor it ran right for a day and then i burnt a piston
Old Dec 6, 2005 | 02:34 PM
platinum00's Avatar
and you put the same fuel mangement on the 2nd motor.
learn from your mistakes and get rid of the FMU.
list a little more detail about your setup
what size turbo?
how much boost?
what size injectors?
what kind and size FMU?
platinum.
Old Dec 10, 2005 | 10:12 AM
the fuel management wasnt the problem on the first motor fuel leak causedthe motor to run lean and then DETONATION
Old Dec 10, 2005 | 10:43 AM
kyden's Avatar
Default Re: turbo problems please help (98redDXturbo)
well first off, you have bigger injectors with no fuel management. this is causing you to run ridiculously rich, washing out your cylinders, thus the gasoline in your oil. second off, the fmu coupled with the injectors is probably flooding out your engine, causing the stuttering.
Luward
Apr 29, 2008 04:46 AM
foreverwefall
33
Nov 18, 2006 04:35 PM
98redDXturbo
Dec 10, 2005 09:59 PM
kholmes
May 10, 2004 07:08 PM
d98integra
Jun 19, 2001 07:08 PM
