7500-8000 rpm bog
Well this is something new for me. I was driving and decided to throttle out and when doing so when the rpm needle hit around 7500, my engine started to make a bogging/choking noise. I kept the throttle down and when it hit around 7900-8000 the needle stopped and it just kept making that bogging noise
. Never have had this problem before. I check the fluids, good. Reset the ecu and still it happens. Is this fuel related? Should I unplug my VAFC? Any ideas or leads would be greatly appreciated.
went outside and found that the dizzy and plugs are in order. Still need to renew the plugs and wires. Figured probably a fuel cut out...tada...check the fp guage and there was only 25-27psi running. Turned it up to about 50-55 and that seemed to solve the problem. Runs right up to redline with no problem. Thanks for the info.
netfreak
Aug 29, 2018 04:57 PM
emotionisdead
Mar 14, 2010 08:46 PM
Anyone else?
