vtec help not working
Old Dec 4, 2005 | 07:09 PM
LsVtakYO's Avatar
Default vtec help not working
ok my buddy has a 1996 honda civic dx and he swapped a b16 into it.we are using a obd2a vtec harness and a jumper to a p28.it only throws one code, code 6 and the vtec does not work.just wondering if anyone knew or had this problem.thanks
Old Dec 4, 2005 | 08:30 PM
HiProfile's Avatar
Default Re: vtec help not working (LsVtakYO)
Well code 6 is the water temp sensor, I'm not sure if its the one on the thermostat or under the dizzy (d16's have a 2nd one there). Chances are you have the two connectors (thermostat temp sensor and vtec solenoid). If that was the case, the ecu would be reading a deactivated vtec solenoid for water temps, and trying to activate vtec with the water sensor. The sensor's connector is typically brown, and usually the vtec connector green.
GL
Old Dec 4, 2005 | 10:20 PM
LsVtakYO's Avatar
Default Re: vtec help not working (HiProfile)
ok so i change the temp sensor?not sure where u were goin there lol
Old Dec 5, 2005 | 10:54 AM
LsVtakYO's Avatar
ttt
t-dizzy
May 18, 2008 01:44 PM
1PT-SICK
Oct 23, 2007 07:39 PM
mikebranson
Apr 13, 2004 09:00 PM
pr3crx
Feb 5, 2004 10:04 AM
jonas
Mar 15, 2003 03:09 PM
