*stumped* engine coolant temperature code?!?! why?
Old Oct 22, 2007 | 08:23 AM
1PT-SICK's Avatar
Default *stumped* engine coolant temperature code?!?! why?
My CRX had a B16 in it, ran perfect no codes. I swap in a different engine, hook everything up (i think the same exact way) and now i have #6 code which is engine coolant temperature. I replaced the sensor right under the vtec solenoid which is i think the coolant temp. sensor. Still throwing the code! the car would begin to overheat so i would turn it off. Please help me solve this. thanks
Just wondering, how many wires does the clip on the Coolant temp have coming out of it? also, how many for the vtec solenoid clip?
Old Oct 22, 2007 | 09:39 AM
standbackimapro's Avatar
The sensor right under the vtec solenoid is the vtec pressure switch
Old Oct 22, 2007 | 01:12 PM
1PT-SICK's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">The sensor right under the vtec solenoid is the vtec pressure switch</TD></TR></TABLE>
no, i didnt mean right like under it...im talking about the one that is on the head, right near head gasket....when i took it out coolant ran out.
Old Oct 22, 2007 | 07:48 PM
1PT-SICK's Avatar
Default Re: (1PT-SICK)
no help?!?! come on "honda-techers"
Old Oct 23, 2007 | 08:20 AM
IN VTEC's Avatar
Default Re: *stumped* engine coolant temperature code?!?! why? (1PT-SICK)
There are two thermosistors that measure coolant temp. One is for the gauge cluster needle and the other one is for the ECU. Make sure you got the two wire one.
Old Oct 23, 2007 | 08:29 AM
all-mtr-teg's Avatar
Default Re: *stumped* engine coolant temperature code?!?! why? (IN VTEC)
correct, one goes into the head, the other on the thermostat housing.
Old Oct 23, 2007 | 08:36 AM
1PT-SICK's Avatar
are you sure? for a B16A OBD0? I thought on the older ones, it was in the back of the block, not on the thermostat housing. damn im so confused, this is kinda pissing me off.
Old Oct 23, 2007 | 10:24 AM
You may be right, im thinking of my buddies 96 del sol
Old Oct 23, 2007 | 07:39 PM
1PT-SICK's Avatar
Default Re: *stumped* engine coolant temperature code?!?! why? (all-mtr-teg)
yea man...so any help or what????
LsVtakYO
Dec 5, 2005 10:54 AM
prelude-bb3
Jul 25, 2004 11:42 PM
mikebranson
Apr 13, 2004 09:00 PM
pr3crx
Feb 5, 2004 10:04 AM
Rob!
13
Apr 13, 2003 12:01 PM
