crazy weird idle going on.
Old Dec 4, 2005 | 06:29 PM
.Kevin.'s Avatar
Default crazy weird idle going on.
Modified by Slow_CvC99 at 3:18 PM 2/19/2006
Old Dec 4, 2005 | 08:04 PM
.Kevin.'s Avatar
Default Re: crazy weird idle going on. (Slow_CvC99)
up.... no one knows?
Old Dec 4, 2005 | 08:32 PM
94hatchling's Avatar
very odd... bump to help a guy out
Old Dec 4, 2005 | 09:34 PM
.Kevin.'s Avatar
Default Re: (94hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">very odd... bump to help a guy out</TD></TR></TABLE>
thanks its bad to if you are driving and let off the gas the entire car shakes
Old Dec 4, 2005 | 10:09 PM
roberts's Avatar
Default Re: (Slow_CvC99)
I had the same problem.. but my idle shaked from 500-2800 RPM. It was a vacuum problem in the intake manifold,but it can also be EACV. Try to buy carburator cleaner.. start engine and spray it all around intake manifold and all air tubes. If your engine like goes down it means it is a vacuum problem and your engine is sucking carb cleaner somewhere when you are spraying it.
If your problem persists try to take off EACV and clean it with the same carburator cleaner.
Old Dec 7, 2005 | 07:01 PM
.Kevin.'s Avatar
Default Re: (roberts)
Modified by Slow_CvC99 at 3:19 PM 2/19/2006
Old Dec 8, 2005 | 09:25 AM
.Kevin.'s Avatar
come on no1
Old Dec 9, 2005 | 11:37 AM
.Kevin.'s Avatar
bump because when i filled up today i figured out my gas milleage and it was 16mpg highway ****** rediculous some1 help
Old Dec 10, 2005 | 04:39 PM
.Kevin.'s Avatar
i got my cel read and its something with the ideal the lady at autozone said the iac valve wat u think?
Old Dec 10, 2005 | 05:40 PM
FalkenSiR's Avatar
Clean out your EACV. All you need is brake cleaner... and don't forget sealant.
Old Dec 11, 2005 | 12:15 PM
.Kevin.'s Avatar
Default Re: crazy weird idle going on. (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Clean out your EACV. All you need is brake cleaner... and don't forget sealant.</TD></TR></TABLE>
Excuse me for my ingonarance but where is the EACV and what am i sealing with it?
whiteEM1
May 24, 2011 01:49 PM
$amGD3
Apr 15, 2007 07:07 PM
d3viant
Dec 31, 2006 09:00 AM
Out of every "game"
Feb 8, 2006 01:12 PM
Shmolie
Jun 29, 2005 05:58 PM
