Help me solve my idle problem
Swaggylicious
All right the car is a '96 Civic EX.D16Y8 motor,stock except for an intake.
The problem
When the car is cold such as in the morning or after being parked a while,I can start the car fine and it will idle ok.The thing is if I have my ac on while my engine is cold,the car will idle for about 3 seconds and it'll die,I have to keep revving it a little(about 1000rpm).As long as the needle doesnt rest the car wont die.
This ONLY happens if the engine is cold,can you guys help me out?
EDIT
<FONT SIZE="5">EDIT,APPARENTLY IT DOESNT MATTER IF I HAVE THE AC ON OR NOT WHEN STARTING IT,I HAVE TO KEEP REVVING IT A LITTLE AND IF THE TACH RESTS,THE CAR WILL DIE.THIS ONLY HAPPENS FOR A MINUTE OR TWO,THEN IT IDLES FINE AND DOESNT DIE</FONT>
Modified by sam21 at 5:48 PM 4/15/2007
The problem
EDIT
Swaggylicious
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Sounds like a belt issue, or you need to raise your idle up.</TD></TR></TABLE>It idles fine when it's warm though,if I raise it anymore it'll be too high.
Which belt are you talking about?
Swaggylicious
Re: (sam21)
SOMEONE HELP ME OUTTTTTT
EDIT
EDIT
Unjockable
05-01-2002 05:56 PM
