crazy weird idle going on.
Re: (94hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling »</TD></TR><TR><TD CLASS="quote">very odd... bump to help a guy out</TD></TR></TABLE>
thanks its bad to if you are driving and let off the gas the entire car shakes
Re: (Slow_CvC99)
I had the same problem.. but my idle shaked from 500-2800 RPM. It was a vacuum problem in the intake manifold,but it can also be EACV. Try to buy carburator cleaner.. start engine and spray it all around intake manifold and all air tubes. If your engine like goes down it means it is a vacuum problem and your engine is sucking carb cleaner somewhere when you are spraying it.
If your problem persists try to take off EACV and clean it with the same carburator cleaner.
Re: crazy weird idle going on. (Slow_CvC99)
bump because when i filled up today i figured out my gas milleage and it was 16mpg highway ****** rediculous some1 help
i got my cel read and its something with the ideal the lady at autozone said the iac valve wat u think?
Re: crazy weird idle going on. (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">Clean out your EACV. All you need is brake cleaner... and don't forget sealant.</TD></TR></TABLE>
Excuse me for my ingonarance but where is the EACV and what am i sealing with it?
