HELP! Broken clutch pedal assembly
Old Dec 3, 2005 | 12:36 PM
pudding's Avatar
Default HELP! Broken clutch pedal assembly
A weld came off on my clutch pedal around the pivot point without me knowing it. like i said i didnt know it so i just kept driving around normally. now my pedal has bent to the right and I cant get enough leverage on my clutch to engage! I need to know if this has happened to anyone and what they did. also, if you can tell me how i can take the pedal assembly out to take it to get rewelded or just replaced that would be great too.
TIA
I forgot to say this is a 91 crx hf with b18b andb16 tranny, but i guess the engine type isnt really need for this anyways is it? Oh well maybe it can help
Old Dec 3, 2005 | 01:07 PM
tyro's Avatar
Default Re: HELP! Broken clutch pedal assembly (pudding)
buy new, only $31 for #20
http://www.slhondaparts.com
Old Dec 3, 2005 | 01:13 PM
d357r0y's Avatar
Default Re: HELP! Broken clutch pedal assembly (tyro)
or buy the whole assembly from me for $25 + shipping
Old Dec 3, 2005 | 01:21 PM
ludesrv's Avatar
Wreckers, pick a new assembly for dirt cheap. Bought mine for 5$ when I did my conversion.
Old Dec 3, 2005 | 01:55 PM
pudding's Avatar
it is broken between piece 23 and 26 i think. the pivot isnt in the hole anymore
Old Dec 3, 2005 | 09:00 PM
MENACE's Avatar
Default Re: (pudding)
When the bar that held my clutch bracket, to the rest of the assembley broke. I just bent it back, and stuck my MIG torch up there, and welded it back together. Held up fine since. This was about 6-7 months ago.
I dont recomend ANYONE, Welding upside down and in there dash tho. I did it because i needed the car back on the road that day. So if your gonna weld it back together, im in no way implying that you weld in your dash.
However in your case it seems replacement may be the only option. Since it broke on the pivot.
Old Dec 3, 2005 | 09:27 PM
pudding's Avatar
ya i cant weld anyways, i still wanna get around to leanring. but its only one side so welding it could be an option if i can find some1 to do it
Old Dec 4, 2005 | 07:10 AM
d16dcoe45's Avatar
That happened to me about 5 years ago, I was driving my car on my way to Englishtown--the clutch pedal pivot broke when I was 30 minutes away. I just unbolted everything and bought a new bracket. It happens because of the heavy pedal pressures, I guess its more common than I thought.
Old Dec 4, 2005 | 10:42 AM
CarAudioPro's Avatar
Default Re: (d16dcoe45)
dude this happend to me in my old hatch, ******* sucks. you have to pull the whole dash to replace it, i just bent it back and had a buddy re-weld it. never broke again, i really didn't want to pull the dash.
Old Dec 4, 2005 | 10:56 AM
dr_latino999's Avatar
Default Re: (CarAudioPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarAudioPro &raquo;</TD></TR><TR><TD CLASS="quote">dude this happend to me in my old hatch, ******* sucks. you have to pull the whole dash to replace it, i just bent it back and had a buddy re-weld it. never broke again, i really didn't want to pull the dash.</TD></TR></TABLE> You don't have to pull the whole dash, you have to remove pretty much everything but the dash -
In no particular order
Steering column
Heater ducts
Fuse box and assorted wires
Takes about 90 minutes to take everything out carefully with hand tools, a little quicker to put it back together.
Old Dec 4, 2005 | 02:05 PM
pudding's Avatar
does anyone have a diagram or step-by-step for taking it out? and i dont have heater ducts, do you think i can work around the steering column?
Stonage07
Mar 6, 2017 11:48 AM
EF-Honda91
Sep 14, 2006 02:42 PM
NoBottleJustThrottle
Jan 22, 2005 10:22 AM
DX187VTEC
Nov 12, 2002 06:41 PM
