So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio....
Old Dec 2, 2005 | 02:04 PM
beandip's Avatar
Default So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio....
But now my A/C - Heat will only work on MAX. WTF, the car runs fine, & the radio works great. Even if I turn it down just a bit, it basically turns off?
Anyone have any ideas?
Yes I already searched.
Modified by beandip at 4:53 PM 12/2/2005
Old Dec 2, 2005 | 02:36 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (beandip)
bad motor
happens quite frequently
Old Dec 2, 2005 | 02:53 PM
beandip's Avatar
Default Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (MugenHonda)
??? Um No.
The A/C Heater was working perfectly fine before I put the Radio in. It still works, but only on MAX A/C, nothing lower.
Old Dec 2, 2005 | 03:14 PM
Karizmah's Avatar
Isn't there a fuse for the lower setting on the fan?
Did you check it yet?
Old Dec 2, 2005 | 03:56 PM
dohcVTECeg2's Avatar
Default Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (Karizmah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karizmah &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there a fuse for the lower setting on the fan?
Did you check it yet?</TD></TR></TABLE>
Old Dec 2, 2005 | 04:18 PM
beandip's Avatar
No, I haven't checked it yet. Will do in about 45min when my lunch comes around =P
Old Dec 2, 2005 | 04:25 PM
anony95ex's Avatar
Check the fuse, make sure you didn't unplug anything on the controls for the HVAC.
Generally speaking though, when you only have high and off, the cause is a bad blower resistor. Could be a coincidence.
Old Dec 2, 2005 | 05:15 PM
intevic_dx's Avatar
check and see if you got all the plugs pushed in securely.
i had the same problem and thats what it was.
Old Dec 2, 2005 | 05:23 PM
JDM-EJ1's Avatar
Default Re: (intevic_dx)
Fuses. Like everyone else stated.
Old Dec 2, 2005 | 05:26 PM
G2 Speed's Avatar
Default Re: So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio.... (anony95ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex &raquo;</TD></TR><TR><TD CLASS="quote">Check the fuse, make sure you didn't unplug anything on the controls for the HVAC.
Generally speaking though, when you only have high and off, the cause is a bad blower resistor. Could be a coincidence.</TD></TR></TABLE>
yea, well my mom's car 99 alero... here air conditioning and heat would only work at 4-6 settings or w/e, I search around turned out to be blower motor resistor.. bought a new one at gm for like 30 bucks and fixied... hardest thing ever to install
Old Dec 6, 2005 | 09:11 AM
beandip's Avatar
Well, I ripped apart the dash again & replugged the cable back in. Perfect.
Even though the thing was plugged, & had to replug it. Go figure. It works.
Thx for the help
Old Dec 6, 2005 | 04:22 PM
intevic_dx's Avatar
ha ha, i was right
always check your work and never jump to conclusion and buy stupid crap thats a bitch to change.
immajackuup
13
May 10, 2008 07:34 AM
HaitianEJ1
Mar 16, 2008 05:46 PM
SpeedoKing
Jun 25, 2007 05:04 PM
doggworld1233
Jun 17, 2006 04:32 PM
Audio28
Audio / Security / Video
Aug 27, 2004 05:36 PM
