dash-gauges-gs-r
https://honda-tech.com/zerothread?id=437408 – GSR Cluster into EG
https://honda-tech.com/zerothread?id=504396 – GSR Cluster into EG
https://honda-tech.com/zerothread?id=304752 – GSR Cluster into EG
https://honda-tech.com/zerothread?id=364837 – GSR Cluster into EG
i pulled these from FAQ's..
just takes a minute and and is stickied at the top of this page
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMbiAtcH »</TD></TR><TR><TD CLASS="quote">What all do you have to do to fit a gs-r dash in a eg.Info please, if any body has done this conversion before. thanks</TD></TR></TABLE>
You have to shave the cluster down so it will fit in the EG dash (cut it down so it's pretty much just the guage faces).
Then you have to use the GSR cluster plugs. This means you have to cut the old ones off your wiring harness and re-wire them to the GSR cluster specs. It's pretty easy wiring to do though. Do a search and you should be able to find the wiring diagram.
again...in faq's
https://honda-tech.com/zerothread?id=285567 – Integra Dash in EG
https://honda-tech.com/zerothread?id=170977 – Integra Dash in EG
93 ferio geezer
Dec 27, 2005 08:11 AM
toeknee360*
Jan 28, 2005 11:24 PM
