TW: 92 hatch si
Old Dec 1, 2005 | 07:54 PM
xracerGS-R's Avatar
Default TW: 92 hatch si
Testing waters on my 92 Si hatch....
good:
everything stock, except for catback piping, intake and headers...
car is lowered on some unknown spring. not sure of the heights...
motor still run strong for a sohc vtec.
bad:
heres the problem with the car, i had to fix the water pump cuss he had went bad, sadly after i placed in the new water pump, my crank pulley is shaking, wobbling like it is loose, i tried fixing it, but i was not successful. I almost postive it is the crank shaft where the pulley connect to is worn out..so you need a new crank....
-may need a paint job ( )
-high milage car (2xx,xxx)
i pick this up a couple month ago for 2800, thinking all i had to change was the water pump, but the crank fucked up on me....
i replaced the sunroof because the previous own had cracked it and cost me about 100 buck and i put in 145 worth to the water pump, tensioner, crank seal, and timing belt.
i want atleast wat i paid (2800)
wat do you guys think...shoot me offers...
Old Dec 4, 2005 | 09:54 PM
xracerGS-R's Avatar
Default Re: TW: 92 hatch si (xracerGS-R)
bump yo
Old Dec 6, 2005 | 09:43 AM
xracerGS-R's Avatar
nobody wants a si hatch
Old Dec 8, 2005 | 09:30 AM
xracerGS-R's Avatar
bump if you read
ACCORDingly94
Engine Machining & Assembly
Jul 27, 2015 12:55 AM
xak98x
Jul 6, 2007 10:29 PM
si_hatch
Dec 20, 2004 04:00 PM
Tad
12
Feb 9, 2004 05:13 PM
