Violent shaking during accelleration
Old Nov 30, 2005 | 11:48 PM
debogsr's Avatar
Default Violent shaking during accelleration
Ive been having a violent shaking during accelation, and I checked out my CV boots. I reaplced the passenger side one less than a month ago, and the other one ripped, so i was certain that it was my problem.
After i replaced the whole Axle on the drivers side, The shaking still was there.
I rotated my tires, and the shaking went away.
My question is.
What is up with my front tires???? Would a flat spot cuase the shaking? or did maybe a weight come off to make them unbalanced?
Thanks everyone
Old Dec 1, 2005 | 12:14 AM
advert's Avatar
Default Re: Violent shaking during accelleration (debogsr)
it could be a bad axel. sounds weird i know cause you just replaced that one. but the thing is i got a new one from napa like a month ago put it in and it was bad. like scary to drive. turns out it did not have the lil balancer on it. got another new one and it works perfect. maybe just bad luck like me
Old Dec 1, 2005 | 12:31 AM
D@nnY's Avatar
Default Re: Violent shaking during accelleration (advert)
its not the boot its the actual joint that goes bad....usually on my car its the driver side one...
just grab the inner joint and see if it moves side to side.....it could be a combo of unbalanced tires and an axle
Old Dec 1, 2005 | 07:29 AM
thinkjdm's Avatar
Default Re: Violent shaking during accelleration (D@nnY)
does your axle have the harmonic balancer?
Old Dec 1, 2005 | 08:21 AM
dc2vu's Avatar
if you changed ur front tires to the rear and it stopped..maybe the wheel needs to be balanced or its bent
Old Dec 1, 2005 | 10:05 PM
debogsr's Avatar
Default Re: (dc2vu)
Yeah both axels are brand new, and also once i rotated the Front to Rear, the Vibration stopped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu &raquo;</TD></TR><TR><TD CLASS="quote">if you changed ur front tires to the rear and it stopped..maybe the wheel needs to be balanced or its bent</TD></TR></TABLE>
I dont think my wheels are bent, but im thinking the balancing is off. Any other opinions?
Old Dec 1, 2005 | 10:26 PM
thinkjdm's Avatar
Default Re: (debogsr)
did u torque down yor axle nut and lug nuts?
Old Dec 1, 2005 | 11:28 PM
burnitup's Avatar
if it went away when you rotated your tires it has to be A. tire B. wheel. Yes a flatspoted tire will do this i have had it happen before the only thing to do is replace it or do a burn out till is all the way smooth around. then drive on it regular for a couple days then balance again. also when you balace your tires the machine will usally tell you if the wheel is bent unless its a cheap machine.
Old Dec 1, 2005 | 11:37 PM
BSP-DC2
Guest
Posts: n/a
Default Re: (burnitup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnitup &raquo;</TD></TR><TR><TD CLASS="quote">if it went away when you rotated your tires it has to be A. tire B. wheel. Yes a flatspoted tire will do this i have had it happen before the only thing to do is replace it or do a burn out till is all the way smooth around. then drive on it regular for a couple days then balance again. also when you balace your tires the machine will usally tell you if the wheel is bent unless its a cheap machine.</TD></TR></TABLE>
Old Dec 1, 2005 | 11:52 PM
debogsr's Avatar
Default Re: (BSP-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinkjdm &raquo;</TD></TR><TR><TD CLASS="quote">did u torque down yor axle nut and lug nuts?</TD></TR></TABLE>
yes
Should i try to get them balanced first to see what it is? Is there any way else to tell what exactly was causing teh vibration?
Thanks for the reply
Old Dec 2, 2005 | 01:25 AM
SlamminS85's Avatar
i posted about this about a month ago, it was a combination of things for me, allignment, old tires with some flat spots, and now i think i have a CV Joint problem, either way im taking it back to the shop to have it alligned because they did a shitty job last month, 3 out of 4 tires have mad camber (tilted in at top) makes turning vibrate
3Rd_gEn_LuDE
Honda Civic (2001 - 2005)
Dec 29, 2011 03:04 PM
KINGVEM^^ED6
Nov 21, 2011 05:44 AM
skata89
Oct 8, 2008 04:11 AM
See Are X
Apr 17, 2006 02:44 PM
kur0ryu
Oct 1, 2004 08:26 AM
