Bad Axle?
Old Sep 25, 2008 | 01:18 PM
skata89's Avatar
Default Bad Axle?
K well just recently Ive had some vibration in the steering wheel and the whole car shakes too. Also yesterday when Im slowing down its making a thumping sound and is really noticable when I turn too. I know what the clicking sounds like but its more of a thumping sound. Should I got ahead and replace the axle?
Old Sep 25, 2008 | 01:24 PM
tegman23's Avatar
I would say to give that a try...I would go under the car and give it a shake to see if it makes a sound...My car did the same thing when it broke car would vibrate under acceleration...
Old Sep 25, 2008 | 01:57 PM
goodtrouble's Avatar
Default Re: (tegman23)
How's the wear in your tires? I was getting alot of vibration above 70mph recently and noticed that it was because my tires were pretty much done. Changed the tires and it ran fine after that.
Old Sep 25, 2008 | 02:08 PM
skata89's Avatar
I know its not the tires cuz it stops when I let off the gas. Is there suppose to be any movement in the axle?
And is there a difference between an ls axle and a type R?
Old Sep 26, 2008 | 01:48 PM
skata89's Avatar
bump
Old Sep 26, 2008 | 02:50 PM
lance_dc2's Avatar
flatened a bearing on inner part of axel.... (tranny side)
and the axels are only different in japan.... if you got japanese type r hubs.
Old Oct 7, 2008 | 02:33 PM
...rohit's Avatar
Default Re: Bad Axle? (skata89)
I have the EXACT same problem I check the wheel bearing (no play really) anyone have any other tips?
Old Oct 7, 2008 | 02:46 PM
seldon's Avatar
try jacking the car up, pull the cv boot back so you can see in at the cv joint, i know my car did the same thing twice now (once on each side). it was the bearings all broke up inside the cv joint
Old Oct 7, 2008 | 06:28 PM
stevelive3's Avatar
Default Re: Bad Axle? (seldon)
my car does the same ****. its only starting off from a dead stop tho. also could a bad axle cause my tranny to shift a little hard?
Old Oct 7, 2008 | 08:11 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: Bad Axle? (stevelive3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevelive3 &raquo;</TD></TR><TR><TD CLASS="quote">my car does the same ****. its only starting off from a dead stop tho. also could a bad axle cause my tranny to shift a little hard?</TD></TR></TABLE>
it could be my car shifts a lil hard, jerks back a lil while driving .. i know my axle is a,most doen i need to replace them soon .. but am broke
Old Oct 7, 2008 | 08:49 PM
AGPDB2's Avatar
It's gonna be the axle. I've gone through a fair share myself. Don't buy remans, it's not worth it. The new ones have the same lifetime warranty at most car part places. I bought mine at NAPA, NEW IN BOX, and haven't had a problem since.
I'd also check your upper Shock mounts... maybe they are a little loose.
That's my 2 cents.
Old Oct 7, 2008 | 11:34 PM
PandaSJ's Avatar
my car does the same thing and shifts a little hard too. i bought my axle, just haven't put it in yet. =P
Old Oct 8, 2008 | 04:11 AM
billabong's Avatar
i get a clicking noise wen starting off in 1st gear from a dead stop or going into reverse from a dead stop. Checked my bearings all fine so im going to replace the axles nd see how that goes
KINGVEM^^ED6
Nov 21, 2011 05:44 AM
debogsr
Dec 2, 2005 01:25 AM
kur0ryu
Oct 1, 2004 08:26 AM
mitsuman
Jan 22, 2003 07:27 PM
skafia
Sep 25, 2002 11:04 PM
