ASAP! Throttle Body cable adjustment.
My thorttle cable is messed up.
When I lift up the gas pedal idle goes down
when im driving and at a stop light it idles from 1k-2.5k until I lift up on the gas pedal.
The thorttle sticks until I lift up the gas pedal
I been playing with it for awhile now and cant seem to get it right.
<FONT SIZE="5">If you see anything wrong tell me!! lol</FONT>
<FONT SIZE="5">Can someone come over and adjust the throttle cable for me!! Socal </FONT>OC/LA area!!
Modified by SkAnK_aSS_BRyAn at 1:19 PM 11/30/2005
Modified by SkAnK_aSS_BRyAn at 1:20 PM 11/30/2005
Modified by SkAnK_aSS_BRyAn at 1:21 PM 11/30/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill »</TD></TR><TR><TD CLASS="quote">seriously, you only need I think a 12mm wrench. loosen the one nut, pull the cable towards the tb, then retighten the nut. shouldn't take more than 5-10 minutes.</TD></TR></TABLE>
I did that many many times.
It never sits right or something it keeps on changing my idle. It always seems to slightly stick sometimes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Thats a Y7 throttle cable with a Y8 manifold right? You need a Y8 throttle cable. </TD></TR></TABLE>
Damn good eye!
yes it is a dx on a ex
So I have to get a new one? I cant use the DX one?
Damn good eye!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">No, its to long (obviously) so it wont sit right. </TD></TR></TABLE>
DAMNIT!! hahaha
DAMNIT!! hahaha
you might also check to see if the throttle body butterfly is sticking a little. if you got the motor used you might need to clean out the throttle body. sometimes when they get dirty and clogged they tend to stick alittle.
but props to the guy who saw the cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">that cable doesn't look like it's routed right.</TD></TR></TABLE>
Its not that its not routed right, its that its the wrong damn cable.
chill out. Yeah, that looks like a y7 with a y8 IM on it. The throttle cable is long, but it'll work fine.
Your idle is EITHER a vacuum leak...
OR, you put the wrong spring on the throttle cable rotor attachment bit. I assume you swapped that and know what im talking about. get a Helms manual and adjust your throttle cable with that nut on the throttle cable holder (the brass colored piece of metal bolted to the manifold with 2 screws.
alias 33
10
Jan 22, 2004 09:30 AM
KTeller8
Aug 2, 2002 02:53 AM
