MSD 6AL IGNITION BOX....Any one tried this out on a SOHC non_V-tec?????
Old Nov 30, 2005 | 10:07 AM
Civiclized's Avatar
Default MSD 6AL IGNITION BOX....Any one tried this out on a SOHC non_V-tec?????
Just got ahold of a MSD6AL igtion box. Gonna hook it upa s soon as it comes.
Just wondering if anyone has already done this and if they liked it or not.
It would also be nice to here what rpm ship they used!
Old Nov 30, 2005 | 10:10 AM
CRXBart's Avatar
Default Re: MSD 6AL IGNITION BOX....Any one tried this out on a SOHC non_V-tec????? (Civiclized)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclized &raquo;</TD></TR><TR><TD CLASS="quote">Just got ahold of a MSD6AL igtion box. Gonna hook it upa s soon as it comes.
It would also be nice to here what rpm ship they used!</TD></TR></TABLE>
It's not really gonna do much for you at all. I would only reccomend a MSD if you have high compression, high boost, or rev hell out of it or any combination of the three. Otherwise it will not be worth it.
Old Nov 30, 2005 | 10:19 AM
crxnj's Avatar
Default Re: MSD 6AL IGNITION BOX....Any one tried this out on a SOHC non_V-tec????? (CRXBart)
Yeah the stock honda ignition is good..Unless you plan on revving to 9k+ its a waste..Unless you just want it for rev limits and 2step..?
Old Nov 30, 2005 | 11:21 AM
jlicrx's Avatar
Default Re: MSD 6AL IGNITION BOX....Any one tried this out on a SOHC non_V-tec????? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the stock honda ignition is good..Unless you plan on revving to 9k+ its a waste..Unless you just want it for rev limits and 2step..?</TD></TR></TABLE>
the stock Honda coils are crap - MSD is much better if you want something reliable - use the MSD external coil with the 6AL
Old Nov 30, 2005 | 01:32 PM
turbodcivic510's Avatar
veeetttaaaaakkk!!!11!!
but like jlicrx said, the external coil with the 6AL its been working for me fine...
Old Dec 1, 2005 | 07:56 AM
Civiclized's Avatar
Default Re: (g1_teg)
Wich rev limiter pill did you use??
Old Dec 1, 2005 | 08:08 AM
jlicrx's Avatar
Default Re: (Civiclized)
your ECU has a built-in rev limiter (fuel cut-off) - depending on what ECU you have, the limit may be different - we just had our chip in the 6AL at a little above the ECU - we had the 6AL so that we could use the 2-step rev limiter for setting launch rpm
Old Dec 1, 2005 | 09:32 AM
Civiclized's Avatar
Default Re: (jlicrx)
From waht I understand my ECU is probably around 6.5 R.P.M. I personally don't try to push it that hard every time I step into it. So I figured I might try achip for 6,000 R.P.M. That with my MSD cap thats already on there, I figure what the heck....
Thanks for the feed back though guys, as always-thanks
layedoutat0psi
13
Nov 20, 2007 12:34 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
Jockobo
Jun 30, 2004 01:46 PM
FastAllmotorLsVtec
Apr 16, 2004 11:12 PM
Jared
Nov 3, 2002 07:09 PM
