Code 43 Problems! help!
Old Nov 30, 2005 | 07:27 AM
b18_crx's Avatar
Default Code 43 Problems! help!
Well my car has been throwing code 43(fuel delivery), 17(VSS), and 1(Primary o2) for sometime now. Haven't been too worried about since i will be convertion to obd-1 here pretty soon. As I was driving this morning my car all of a sudden started feeling very sluggish and very slow. IT felt like I was driving my old DX! The car idles fine and will move but my question is what could be wrong? Im betting money its either the FPR or maybe an injector. Any Input appreciated
I SEARCHED OK!
Old Nov 30, 2005 | 08:02 AM
Dominox972's Avatar
Default Re: Code 43 Problems! help! (b18_crx)
i would check the injector and fuel filter first.. then try some rxp..
Old Nov 30, 2005 | 08:20 AM
ironcheftony's Avatar
change the o2 sensor with a good known working o2 sensor
Old Nov 30, 2005 | 08:32 AM
b18_crx's Avatar
Default Re: (ironcheftony)
talked to Allan (Ch3mik) and said it may be fuel filter>?
Old Nov 30, 2005 | 08:49 AM
Dominox972's Avatar
Default Re: (b18_crx)
Well the last time something last this happen to my friend delsol... was running sluggish.. he chg out the injector and it rain good.. so it can be a few things... good luck
Old Nov 30, 2005 | 09:35 AM
b18_crx's Avatar
Default Re: (Dominox972)
yeah thats the bad thing about code 43 its not very specific........i dont think its fuel pump because it idles fine
Old Nov 30, 2005 | 10:29 AM
b18_crx's Avatar
anyone else?
Old Nov 30, 2005 | 11:06 AM
Jonathan_ED3's Avatar
I'd say check the injectors.
Do you have a Helms?
You're going to need to grab a multimeter and have the injector specs handy.
Old Nov 30, 2005 | 11:39 AM
b18_crx's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">I'd say check the injectors.
You're going to need to grab a multimeter and have the injector specs handy. </TD></TR></TABLE>
yeah thats what i was going to do tonite as soon as i got home! im hoping its an injector...........and it would be an easy fix!
Old Nov 30, 2005 | 11:44 AM
neutron91's Avatar
i had a code 43... ended up being the tip of the injector was cracked and it caused the pintle to stay stuck open so it was spraying fuel the whole time... it also got horrible gas mileage and sounded like it was misfiring... i would also check the o2, fuel filter, fuel rail, etc
Old Nov 30, 2005 | 11:46 AM
b18_crx's Avatar
Default Re: (neutron91)
yeah im planing on replacing fuel filter and maybe do an aftermarket fpr.........
Old Nov 30, 2005 | 11:59 AM
Ch3mik's Avatar
u dont need no aftermarket FPR foo. check the filter first. check your vacuum lines also. I had a similiar situation once. ended bein an unplugged line, car ran like crap and stunk. get the 02 replaced as well
Old Nov 30, 2005 | 02:17 PM
Dominox972's Avatar
Default Re: (Ch3mik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">u dont need no aftermarket FPR foo. check the filter first. check your vacuum lines also. I had a similiar situation once. ended bein an unplugged line, car ran like crap and stunk. get the 02 replaced as well</TD></TR></TABLE>
YOU SHOULD BUY A ELEMENT! HAHA PROBLEM SOLVE!!!
Old Nov 30, 2005 | 02:37 PM
b18_crx's Avatar
on the way home threw code 4 as well!
Old Dec 2, 2005 | 04:09 AM
b18_crx's Avatar
bought a new dizzy no start now..................... the old dizzy was real hard to move and my friend said it might have knocked the car out of timing.........
i think the vatozone dizzy that i bought is a dud........ ill go exchange it after work today!
Old Dec 2, 2005 | 06:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">i think the vatozone dizzy that i bought is a dud........ ill go exchange it after work today!</TD></TR></TABLE>
Ahaha, i thought I was the only one that said vatozone.
Old Dec 2, 2005 | 06:54 AM
b18_crx's Avatar
Ahaha, i thought I was the only one that said vatozone. </TD></TR></TABLE>
haha LOL.......... if it is outta timing ima need some one to help me set it back!
Old Dec 3, 2005 | 05:00 AM
b18_crx's Avatar
tried a known good dizzy no start...........timing is off!
Old Dec 3, 2005 | 06:50 AM
gofastmobile's Avatar
i was gonna say that your cat might be clogging up...i had a similar problem and that is what it was. do you have a cat?
Old Dec 3, 2005 | 07:22 AM
b18_crx's Avatar
Default Re: Code 43 Problems! help! (gofastmobile)
yep!
Old Dec 3, 2005 | 12:08 PM
theinfamouskonrad's Avatar
I had problems with code 43 a few times now. 1st time it was because 1 of the clips for the injectors wasn't completely down....looked like it was but clicked in when i pushed it in. (that'll do it if you don't have the metal clip going around it to hold it down) Another time it was simply just the o2 sensor.
gazaaccord
Sep 27, 2013 03:27 PM
96civich22
Feb 12, 2005 05:24 AM
PhilStubbs
Jan 22, 2005 11:20 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
importimage
Jun 30, 2003 04:27 PM
