ECU Pins
i'm swapping a b16a1 into my 91 crx si and i am on the search for ECU pins for the few wires i need to add to my connectors. everyone says go to the dealer, so today i went over to acura and they knew what i was talking about but didnt seem to know if/where they had them. so i went across the highway over to honda and they said the exact same thing. i've also called around to local performance shops but have had no luck. besides a yard, does anyone know of a good source? i of course only need a few. all help is appreciated
thanks!
thanks!
I gave them a call upon reading this topic. The guy told me he doesn't have it, or know of the part number.
I'd also like to know this answer too.
I remember ALONG time ago, back on the real old Hybrid board, someone had posted a part number to this kit....I'll be damned if I can find it anywhere though.
Just go to the junkyard and cut some plugs out of a car.
If you get the pins from Honda/Acura you need to crimp on the wire. It can be done with any pair of needle nose pliers but it may not hold. You need a special crimping tool. Trust me on this one...
-kenji
-kenji
Keebler,
You are correct in stating that you could solder it as well as crimp it with a pair of pliers. I have done this before and it does work. It is just time consuming. If you are only doing a couple of pins it is no big deal.
Good luck with what ever path you choose.
-kenji
-kenji
hard_boiled_EG
Oct 15, 2009 05:16 PM
