headgasket leaking or blown someone approve what i found.
Old Nov 28, 2005 | 05:10 PM
eg2wes's Avatar
Default headgasket leaking or blown someone approve what i found.
ok past couple days i have had this horrid sweet smell in my exhuast, very familiar smell from when a friend blew a headgasket in his dc2, so today i finally got a chance to take a look, pulled the plugs, very little oil on all 4 plugs also found i am running lean as ****, plugs smelt sweet also. checked the coolant (drained and drained the coolant resivior) had some oil in it. so i flushed the coolant system and refilled it. planning on checking it again to see how much oil i am actually mixing with coolant.
i am leaning towards the idea that i have a leaking headgasket, anyone wanna back me up on my findings and sorry i havent been able to a compression nor leakdown test, i'll have it done friday tho.
and for sake of not making another thread for the same topic, i know that by running a thinner headgasket i can boost compression, so while i am most likely going to be changing my headgasket anyone want to point me in the direction of a headgasket that will boost my compression just a little btw i am running a jdm d15b.
thanks everyone for you imput but please no bullshit.
Old Nov 28, 2005 | 05:17 PM
seeeya04's Avatar
Default Re: headgasket leaking or blown someone approve what i found. (eg2wes)
You need to just buy a new head gasket.
And for get about boosting your compression the only real way to get power out of the d series is fI boost it
Old Nov 28, 2005 | 05:27 PM
eg2wes's Avatar
i'm not trying to get much more HP 5-10 would be fine for me, the sol is just my daily driver now days so i'm not looking to dump 2k into a good turbo setup. i just want it to be a little peppier and since it has to be changed to begin with why not go ahead and put a better headgasket on.
Old Nov 28, 2005 | 05:32 PM
seeeya04's Avatar
Default Re: (eg2wes)
Well just buy a oem hg and be done with the porb make sure you torque the head to proper specs i learned my lesson on my swapped civic..nasty
Old Dec 18, 2005 | 09:08 AM
RICE POLICE SIP's Avatar
Default Re: (seeeya04)
You can get a thinner HG if you want. Cometics sells them and a couple of other companies, I just can't think of them right now.... Just make sure you follow the proper sequence when taking the head off.. GL
shane
Old Dec 25, 2005 | 03:39 PM
jdm y0's Avatar
Default Re: (Split Image Prez)
d
Old Dec 25, 2005 | 05:11 PM
.Kevin.'s Avatar
Default Re: (jdm y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm y0 &raquo;</TD></TR><TR><TD CLASS="quote">d</TD></TR></TABLE>
Why did you bump this?
avotegra
Dec 13, 2009 11:45 PM
an2ny888
Jul 4, 2008 07:40 AM
Driven
11
Oct 29, 2004 11:41 AM
Sleek98
10
Sep 19, 2003 10:58 PM
PrecisionH23a
Nov 14, 2002 10:16 AM
