93' shoulder belt rail stopped
Old Nov 27, 2005 | 12:42 PM
saminhnl's Avatar
Default 93' shoulder belt rail stopped
I searched recent and new , did not find anything related to the shoulder belt rail.
My 93' has the retracable shoulder belt and has stopped retracting.
It has stopped in the forward position, and gave no indication of a malfunction before it stopped working. It just stopped cold. I did notice that just before it stopped ( 2 engine starts ), the door open beeping persisted to beep ( 2 times ) after door close and acceleration. I open/closed door, and it stopped. Then, the next time I went somewhere,
the shoulder belt would not retract. From what i know, the door beep switch, is not the switch that actuates the Belt. But, it may tie in in the circuit somehow. The switch for the rail is in the door latch itself. Anyone experience anything similar ? TIA.
Old Nov 27, 2005 | 12:43 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: 93' shoulder belt rail stopped (saminhnl)
I believe anything seatbelt related has a 100% lifetime warranty. Take it to the dealer and they will repair it for you.
Old Nov 27, 2005 | 12:49 PM
saminhnl's Avatar
Default Re: 93' shoulder belt rail stopped (shamoo)
Thank you, I did not know that.
Old Nov 27, 2005 | 01:50 PM
92integraVTECgsr's Avatar
the belt could just be stuck.. check to see if the belt tension is tight. mine happened like that, and the belt was just jammed and was so tight it would allow itself to move anywhere and would beep and do what yours is saying..
if its not that.. check fuses or something, if still..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">I believe anything seatbelt related has a 100% lifetime warranty. Take it to the dealer and they will repair it for you.</TD></TR></TABLE>
do what he says.
Old Nov 27, 2005 | 02:26 PM
Deano_D aka
Default Re: 93' shoulder belt rail stopped (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">the belt could just be stuck.. check to see if the belt tension is tight. mine happened like that, and the belt was just jammed and was so tight it would allow itself to move anywhere and would beep and do what yours is saying..
do what he says. </TD></TR></TABLE>
I did not realize how much a DA belt could cut off your breathing until that happend to me haha.
Old Nov 27, 2005 | 03:47 PM
ebonyrolla7's Avatar
i have the same damn problem...its covered by warranty? word
Old Nov 27, 2005 | 06:19 PM
saminhnl's Avatar
I tried to find the legaleeze to cover this , but have had no luck.
Can you tell me where to look, so I can give it to the dealer ?
Thanks
Old Nov 27, 2005 | 07:32 PM
lossleeper's Avatar
It says it in your owners manual, Lifetime Warranty.
brandon.kerlee
Jun 1, 2016 02:27 AM
geetee74
Feb 18, 2011 08:40 PM
Tony the Tiger
May 10, 2002 12:28 PM
J T*
14
Apr 5, 2002 06:21 PM
