Belt molding replacement
Old May 30, 2016 | 05:34 PM
brandon.kerlee's Avatar
Default Belt molding replacement
Would I need to replace the whole door if part of the outer window trim and door is bent out from someone trying to break into it? There's a gap now that water leaks into because the seal doesn't sit flush against the glass?? Not sure why the pictures are upside down
Old Jun 1, 2016 | 02:27 AM
94EG8's Avatar
Seagull Management
Default Re: Belt molding replacement
Moved this post into it's own thread since it didn't belong where it was.
Simply replace the belt molding, the door itself is fine.
stegs
Apr 2, 2008 04:36 PM
saminhnl
Nov 27, 2005 07:32 PM
katb16vo
Mar 18, 2004 09:48 PM
91 civic
11
Jan 24, 2003 06:34 AM
