car turns off when idle! HELP PLEASE
when i turn on the car, the car will completely turn off in a few seconds...And this only happens on cold start ups. When the car has warmed up it is fine..
Does anyone know the cause of this?
i have an 88 honda civic
imskatencrazy....its a fuel pump problem?
civic_driver...how do i check if i get enough air?
update:
the moment the car turns on it turns off right away. The only way to keep it going is by applying gas when the i turn the car on.
update:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imskatencrzy »</TD></TR><TR><TD CLASS="quote">fuel pump relay man. under the dash. drivers side. grey box. 70 bucks at hondaaaaa</TD></TR></TABLE>
If it was that, it wouldn't start at all. Since it runs when you're on the gas, I'd say it's the FITV; it holds the idle high on cold startups.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">that's the carburator right?</TD></TR></TABLE>
Oh, just saw this. If it's carburated, possibly the choke / butterfly valve? Check with the EF forum, this one is for 92-00 civics.
bogus_ek
Jun 4, 2004 10:18 AM
