How do you install this...?
Old Nov 26, 2005 | 04:13 PM
AMECustom's Avatar
Default How do you install this...?
This is the door lock mechanism for 92-95 civic EX's. I can figure out how to install these on my car. Does it go on the part where the handle connects to or does it go to where this part, look at the circled portion in the picture. I have searched and cant find anything that shows you if this is the right part.
Old Nov 26, 2005 | 04:34 PM
AMECustom's Avatar
Default Re: How do you install this...? (AMECustom)
anyone????
Old Nov 26, 2005 | 05:25 PM
AMECustom's Avatar
OMFG!!!
Old Nov 26, 2005 | 05:33 PM
Sliced Beard's Avatar
it attaches to teh circled portion and has a linkage rod connecting to it
(look in the picture, you can see the blue colored pigtail coming from the circled section)
Honda color codes wires for a reason
Old Nov 26, 2005 | 06:24 PM
AMECustom's Avatar
Default Re: How do you install this...? (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">it attaches to teh circled portion and has a linkage rod connecting to it
Honda color codes wires for a reason</TD></TR></TABLE>
I know which plug it plugs into, thats not my question. I dont know how it mounts in the "circle". Could you help me more please...
Old Nov 26, 2005 | 06:26 PM
might be able to copy the Helms ewxplanation of doing so.....possibly
Old Nov 26, 2005 | 06:28 PM
AMECustom's Avatar
dude if u could ^^^ i would be so greatful, i need to get this thing done lol
Old Nov 26, 2005 | 06:36 PM
I could not copy and paste due to Adobe Acrobat reader being ghey but I will just type it out for you........
1.Remove door panel, plastic cover, and center channel
2. Pry the outer handle rod and cylinder rod out of its joint using a flat tip screwdriver. Disconnect and detach the connector from the door. Detach the inner handle rod and lock rod from the door. Remove the screws on the outside of the door that surround the latch mechanism then remove the latch through the hole in the door.
3. Remove the control module from the lock mechanism by removing the hardware that attaches it to the assembly.
4. Installation is reverse of the removal procedure.
Old Nov 26, 2005 | 06:38 PM
that has to be the simplest door lock actuators I have ever seen to remove, I don not understand why you were not able to figure it out.....
or maybe I am saying this becasue I work on Honda's every day of my life
Old Nov 26, 2005 | 06:41 PM
hatchi's Avatar
there are 3 small screws that hold it in place. the little white tab is fragile so be careful not to break it. its kind of hard to explain. ill try to get you pictures
Old Nov 26, 2005 | 06:43 PM
AMECustom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">that has to be the simplest door lock actuators I have ever seen to remove, I don not understand why you were not able to figure it out.....
or maybe I am saying this becasue I work on Honda's every day of my life</TD></TR></TABLE>
oh ****, so the power lock regulator connects to the door latch? **** if thats the case then you will understand why i couldnt figure it out. I was trying to connect it to a manual door latch. So i need the power door latch? **** the guy didnt send me that DAAAAAAAAAMNIT!
Old Nov 26, 2005 | 06:47 PM
haha
Old Nov 26, 2005 | 06:48 PM
I can get it for you if you would like and you pay freight......or you can just go to http://www.hondaautomotiveparts.com and get the mechanism for a 93-95 EX/SI
petwhookie
Audio / Security / Video
27
Oct 25, 2008 08:16 PM
Powered by VTEC
Jan 26, 2008 09:03 PM
Disjayfo0
13
Jan 14, 2008 11:19 AM
85
Honda Motorcycles
12
Jul 6, 2005 10:48 AM
VTECej1
20
Jul 21, 2004 12:50 PM
