ECU questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 »</TD></TR><TR><TD CLASS="quote">ok what will i do to make it work and whats the problems i might have once i install it?</TD></TR></TABLE>
If im right, the only differences are that it is looking to see if the car is in park before it is started. It probably wont start. I know there's a way to convert them, but since most people are giving them away for free just find a new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">
Naw, all the interlock junk is done outside of the ecu. The auto ecus just look for the torque convertor lockup solenoid, and control it. Converting to manual is a matter of switching some jumpers, but I'm confused on a couple points here. First, is your D15B multi point? If you've got 2 injectors, it won't work. Second, the P08 is OBD1, so unless you've converted to OBD1, it won't even plug up. Third, it's for a vtec engine, so you'll have to disable vtec in the ecu or it will be pissed.
</TD></TR></TABLE>Naw, all the interlock junk is done outside of the ecu. The auto ecus just look for the torque convertor lockup solenoid, and control it. Converting to manual is a matter of switching some jumpers, but I'm confused on a couple points here. First, is your D15B multi point? If you've got 2 injectors, it won't work. Second, the P08 is OBD1, so unless you've converted to OBD1, it won't even plug up. Third, it's for a vtec engine, so you'll have to disable vtec in the ecu or it will be pissed.
as it is it will run... it will just throw a code for trans lock-up soleniod.
you can also convert it to manual to get rid of the cel.. dude above i think posted a link, if not pm me and i'll send you some diagrams. its easy stuff
obd1 po8 auto to manual.
remove rp17 remove rp18 add a jumper to rp18
open up your ecu, look at the circuit board. next to just about every componenet is a printed label on the board. you find rp17 and rp18, and then get a small peice of wire to cross the 2 holes left by the removal of rp18. i cant tell you where they are located because i havent done an obd1 conversion, but they may be on the side with the plugs about the middle of the board near the edge. but i cant guarantee that. just look.
ok i found rp18 and rp17 but they doesnt look like the pictures u posted, i have JDM ecu p08 and the r on the back side
u said you'll need to lower the value from 2.4k ohms to 1.4k ohms.
how can i do that
Modified by zenon8890 at 3:46 PM 12/1/2005
how can i do that
how can i do that</TD></TR></TABLE>
You need to replace the 2.4K resistor with a 1.4K resistor, which is available from several parts places online, or off a junked ecu. I'm not sure part numbers or anything like that.
sohc_freak
15
Apr 22, 2006 03:26 PM
where's the jumpers and everything else plz
