Hard brakes
How hard is it to swap out rotors and pads by myself.....i never have dealt with them on my own.....with a manual can i do it by myself with average tools?
its really easy.....2 bolts for caliper 2 bolts for caliper bracket and 2 screws for rotors......be careful you dont strip them they are a bitch to remove sometimes.....almost forgot you need a bolt that fits into the holes in the rotor to pop them off....not the hole for the screws the other ones
In doing a pad / rotor swap do i need to replace the caliper and also do i need to bleed anything?---sorry for the questions just im a noob trying to learn
no you dont need to replace the caliper. Just go to auto zone and pick up some brake pads and go at it. Super easy to do. No bleeding required for what your doing. Best way to learn is to roll your sleeves up and get in there. If you have a question while in the middle of your job, take a break and take a trip to Honda-tech. good luck and have fun
jdmekrobot
14
Mar 19, 2008 02:28 PM
