89 crx cranks, no start - good diagnosing needed please
Old Nov 25, 2005 | 09:48 PM
ham's Avatar
ham
Default 89 crx cranks, no start - good diagnosing needed please
89 si cranks but wont start. Died while driving out of nowhere. Here is the info...
No power to fuel pump or ECU when key is turned on
CEL comes on when key is turned on but doesnt go back off, no click sound
What was checked:
Main relay - tried 2
ECU - tried 2
dizzy - swapped to different one
ALL fuses and relays - everything seems good and normal
It appears no voltage is getting to the main relay to let it give power to everything else. I was REALLY hoping it was the main relay, but it is NOT.
Old Nov 25, 2005 | 09:54 PM
88_DX's Avatar
Default Re: 89 crx cranks, no start - good diagnosing needed please (ham)
check ground to the T-stat housing.
Old Nov 25, 2005 | 10:05 PM
ham's Avatar
ham
Default Re: 89 crx cranks, no start - good diagnosing needed please (88_DX)
k thanks.... ill do that and im gonna do the helms flowchart
Old Nov 25, 2005 | 10:07 PM
EF8IGHT's Avatar
sounds like the tstat housing ground same thing happened to me
Old Nov 25, 2005 | 10:17 PM
ham's Avatar
ham
Default Re: 89 crx cranks, no start - good diagnosing needed please (EF8IGHT)
what really gets me is how the CEL doesnt turn back off. With these symptoms, usually the CEL will come on and blink off like it should, but it wont click.
Modified by ham at 2:27 AM 11/26/2005
Old Nov 25, 2005 | 10:53 PM
88_DX's Avatar
If that ground isn't hooked up too the thermostat you will get a solid cel like you have. thats a major ground for all your sensors. just double check that its only a 10mm and it takes 10 seconds to do. Hope its something simple for you I hate dumb probs
Old Nov 25, 2005 | 11:04 PM
ham's Avatar
ham
yeah man.... i HATE these dumb problems. i feel bad for some technicians that have to diagnose problems like this...... sometimes it takes me days to figure out small - easy fix problems like this.
Old Nov 26, 2005 | 10:15 AM
ham's Avatar
ham
cleaned the Tstat ground, resoldered the main relay, and changed fuse 14. runs like a champ!
Old Nov 26, 2005 | 10:57 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Fuse #14 labeled alternator/solenoid valve..
I pushed my car about a mile because of it...
WideBodyTypeR
May 29, 2012 04:36 PM
Jimster480
Feb 15, 2009 09:10 PM
hotinteggy
Oct 22, 2007 04:44 PM
illestrolla247
Apr 4, 2005 06:24 PM
lonefuzzy79
Dec 16, 2003 12:37 PM
