H22: Custom Fuel line.
Old Nov 25, 2005 | 09:40 PM
lak8's Avatar
Default H22: Custom Fuel line.
Hello,
first off i searched may times but nothing really comes up. I know alot of people just use a h23 fuel rail and use the stock line, but i already cut my line and dont have a usdm rail.
I want to make a custom braided ss line that will connect right to the stock filter and to the h22a fuel rail. heres the problem. what connections should i use and what type/model. All i know is the stock uses banjo style connectors to go from the filter to the rail.
Im hopeing some one knows the answer for me and all others that ask this question quite abit but never really gets answered. So what types and size of connectors are used?
Dan
Old Nov 26, 2005 | 04:57 AM
v4lu3s's Avatar
RTFM
for my custom stuff i use an aftermrket rail, -6 lines and -6 an fittings.
Old Nov 26, 2005 | 09:21 AM
NXLude's Avatar
^^^I did the same thing, used aftermarket rail and filter -6 lines and a couple of 90s.....looked really pretty actually
Old Nov 28, 2005 | 01:15 PM
lak8's Avatar
Default Re: (NXLude)
well i looked into it and making a custom line with all the fittings i need might be fairly pricey. i may go aftermarket rail and just a normal ss line.
If anyone has pictures of there setup's please post them
Old Nov 28, 2005 | 03:00 PM
HavokB18's Avatar
braided line and AN fitting. easiest way.
Old Nov 28, 2005 | 03:31 PM
xv53's Avatar
Default Re: (lak8)
Call FAST-TURBO.COM. ask for Stan or IM him I think he's screen name on HT is Flamenco-T. He'll make the steel braided lines and fitting for you with what ever setup you have. I think it was 125 shipped or somewhere around there for the line from the fuel filter to the fuel rail, from the rail to the regulator, and from the regulator to the fuel return line. He gave me a deal for the steel braided lines, GE fuel rail and Aeromotive fpr. This was for an h22 setup in an EG.
Old Nov 28, 2005 | 03:32 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: H22: Custom Fuel line. (lak8)
I remember on my H22 crx I had to relocate my fuel line to the driver side. There was a guy local who used the OEM banjo fittings that were cut down the line and was able to use them to make a longer fuel line costed me like $20 lol
I guess there are some good places in Shelton WA! haha
Old Nov 28, 2005 | 03:43 PM
Turbogixxer's Avatar
Default Re: H22: Custom Fuel line. (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">I remember on my H22 crx I had to relocate my fuel line to the driver side. There was a guy local who used the OEM banjo fittings that were cut down the line and was able to use them to make a longer fuel line costed me like $20 lol
I guess there are some good places in Shelton WA! haha</TD></TR></TABLE>
Only thing with that, some hose places will not not touch it because it have to be DOT complaint. Some shops are cool about it others are dicks.
Old Nov 29, 2005 | 05:25 AM
Specail Ed's Avatar
Default Re: H22: Custom Fuel line. (Turbogixxer)
I took my stock line to a machine shop. They removed the fittings and pressed them on to a longer line. It only cost me about 15 bucks. Just a thought.
Old Dec 11, 2005 | 08:58 AM
Banned.
True turbogixxer but if it works it works....
Old Dec 12, 2005 | 08:15 PM
slim9300's Avatar
Default Re: H22: Custom Fuel line. (Specail Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed &raquo;</TD></TR><TR><TD CLASS="quote">I took my stock line to a machine shop. They removed the fittings and pressed them on to a longer line. It only cost me about 15 bucks. Just a thought.</TD></TR></TABLE>
This is what I did originally. It was a mistake, the longer line affects the fuel delivery and fuel pressure in actual driving situations. When I switched to a 90-93 Accord fuel rail and stock length fuel line it really made a difference in the run-ability of the motor. I would suggest keeping the length of the fuel line stock, unless you have a fpr to regulate the slight drop in fuel pressure. It may seem petty, but it made a noticeable difference for me.
Old Dec 13, 2005 | 12:50 AM
lak8's Avatar
Default Re: H22: Custom Fuel line. (slim9300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">
This is what I did originally. It was a mistake, the longer line affects the fuel delivery and fuel pressure in actual driving situations. When I switched to a 90-93 Accord fuel rail and stock length fuel line it really made a difference in the run-ability of the motor. I would suggest keeping the length of the fuel line stock, unless you have a fpr to regulate the slight drop in fuel pressure. It may seem petty, but it made a noticeable difference for me. </TD></TR></TABLE>
heh, i never knew that. Good info ^^^
Just an update. I bought a str fuel rail and a SS braided fuel line. Should do the trick I didnt want to go cheap on something as important as this.
For all wondering i got the fuel rail off ebay and the fuel line from Flamenco-T heres the link if anyone is interested https://honda-tech.com/zerothread?id=1011936 altho i havnt tried out the parts yet sence there still being shipped but should work perfect
Old Dec 13, 2005 | 12:58 AM
hondaZvic's Avatar
heres some pix of mine...
-aeromotive fpr w/ jeggs liquid filled gauge
-golden eagle fuel rail
-flamenco t's ss lines & fittings
Old Dec 13, 2005 | 12:37 PM
lak8's Avatar
ive seen your fuel setup when searching before, very nice i must say!. mines going to be about the same but without the fpr and the extra lines, i might install a fpg on the fuel rail tho .
Old Dec 13, 2005 | 01:19 PM
EK9-Stealth's Avatar
i just ordered some lines and fittings from summit racing. -6 AN hose, -6 AN 12mm 1.25 banjo. You can use banjo on both fuel rail and fuel filter with a gauge ontop of fuel filter or you can get a 12mm/-6 an male to connect to the filter then get a -6 AN female/ -6 AN hose connector.
Old Dec 13, 2005 | 07:25 PM
hondaZvic's Avatar
Default Re: (lak8)
thanks yO!!
when u get it finished, post up some pix, i wanna see how urs comes out.
sk8shorty012
May 6, 2009 12:10 PM
TheMaroonAvenger
Jul 14, 2007 07:04 PM
zc911
Dec 20, 2003 10:37 AM
98HB
Mar 25, 2003 02:37 PM
Flamenco-T
Aug 4, 2002 04:57 PM
